Civic, Integra... K20a2... lots of parts... need gone ASAP
Old Jun 1, 2008 | 11:13 AM
neutron91's Avatar
Default Civic, Integra... K20a2... lots of parts... need gone ASAP
Have a bunch of parts I need to get rid of... out of the Honda scene so I have no reason to keep any of this... i will ship at your expense... paypal verified... if local to DFW area you can come pick it up but i am unable to deliver
MISC...
-I just aquired a complete K20a2 motor and engine wiring harness from 03 RSX-S... it was hydrolocked and most likely bent a rod... it was replaced at my work and is 100% legit... $1000... will not ship this local only please
-Brand new D series lightweight flywheel... unsure of brand... $60
-97 GSR master cylinder/brake booster... also have the fittings if you plan on upgrading your EG when you do a rear disc conversion... $75
-Pair of yellow H4 bulbs... $10
-88-00 civic, 90-01 integra single bend short shifter... $30
-94-01 integra rear T bracket... needed for B swaps in an EG... $40
-88-91 civic/crx si ecu... pm6... $20
-B20 ecu from a crv... $20
-Civic/Integra lower balljoints... brand new in box... $30
-Civic/Integra outer tie rods... brand new in box... $40
-Civic/Integra inner tie rods... brand new in box... works on models with power steering... $40
-Civic/Integra brackets and bolts that connect the shifter to the shift linkage... also have rubber boot to cover the top... $10
-88-91 EF civic ignition switch wiring harness... not the actual switch where the key goes in but the harness behind it that connects it to the fuse box... $20
92-95 Civic EG...
-Uncut z6 (ex/si) engine wiring harness... $100
-EG radio/climate control bezel... uncracked... $30
-EG cassette player... $20
-EG SRS unit for car WITHOUT cruise control... $30
-EG SRS cable reel... $30
-EG defrost switch... $10
-EG dimmer switch... $10
-EG rear upper control arms... good bushings... $20
-EG hood release lever... black... $10
-EG a/c coil and clutch assembly... $20
-EG headlight and wiper switch assembly... wiper switch broken but still functional... $10
-EG JDM 2dr/hatch passenger inner taillight only... $10
-EG JDM Stanley clear foglight... this is the light ONLY... no bracket/cover/etc... $20
B Series...
-B16 crank pulley... $20
-Flywheel/clutch bolts... $20
-Rear main seal cover... $10
-Timing belt tensioner with bolts/spring... $10
-OBD2 speed sensor... should work with OBD1 as well... $30
Old Jun 2, 2008 | 09:30 AM
neutron91's Avatar
Default Re: Civic, Integra... K20a2... lots of parts... need gone ASAP (neutron91)
ttt
Old Jun 5, 2008 | 09:48 PM
nycjdmwhore's Avatar
pmed
neutron91
Texas -OK -LA (Sales)
Jun 13, 2008 02:09 PM
neutron91
10
May 14, 2008 11:26 AM
kpop
Northern California (Sales)
Feb 25, 2007 09:26 PM
