H22 Bare Port and Polished head with caps, B16a long block, bseries parts, h series parts
Located In Orange County California....Willing to ship at buyers exspence
-H series TWM 50mm itbs complet wtih sensors, plugs, injectors built in vacume box, fuel rail and fuel presure regulator. Comes with bosch style injectors so you cant used oem injectors $1500
-H series with Quaife lsd slight grind in high 4th gear may have been because of a bad clutch but Im not sure...$1200
-H series trans case with internals un assembled...$150
-New H series bdl blue fuel rail.....$100
-b series stock axles with half shaft....$100
-New b series 6 puck clutch with pressure plate and baring for a hydro trans.... $300
-New b series radiator hoses.....$100
-New b series starter....$80
-b series alternator...$75
-Newb series alternator belt.... $50
-msd 6 al ignition... $100
-Auto meter phantom monster tach with shift light.... $125
Modified by DxTrix at 12:27 PM 6/1/2008
Modified by DxTrix at 12:41 PM 10/22/2008
Here is a link that should work with a few pics of the itbs. If it does not work I will get some to you by tomorrow or later today.
https://honda-tech.com/zerothread?id=2160100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix »</TD></TR><TR><TD CLASS="quote">
to some interest!!</TD></TR></TABLE>
what kind of clutch is that? you got any pictures? email mafil25@yahoo.com
I will get the pics and the information on the clutch to you later today.
