Leaking oil from beneath, HeLP!!
To make this short:
Car: 95 Civic Si (D16Z6)
Problem: Have been leaking a lot of oil from somewhere beside the oil pan. I replaced the oil pan gasket but that was not the problem because it still leaks. I looked under the car and I saw an oil drop on the bottom of the flywheel cover. The cover has a little tiny hole at the very bottom (breather??) and it looks like that is where it is leaking from.
Some people tell me I need to replace my crank seal? Has anyone had this kind of problem ??
Thank you.
Thank you.
EG-SIXV-TEC
May 10, 2012 06:56 AM
