My ultra slow k24/k20 Crx project
Hey this is my super slow k24/k20 head crx 89 si project, That I've been lagging on since October 2005. Hold on ill have the pictures back up when i get some more new ones
Modified by ungcobob at 7:38 PM 10/7/2008
it was just a technical course, i dynoed the engine it made 100 horse power to wheel on a dyno dynamic, and 120 calculated flywheel torque
Have you test fitted the K24 with K20 head for hood clearance? I know the K20 with JDM style hood will clear with some trimming of the webbing but wasn't sure about the K24/20 (K24 is taller).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">Have you test fitted the K24 with K20 head for hood clearance? I know the K20 with JDM style hood will clear with some trimming of the webbing but wasn't sure about the K24/20 (K24 is taller).</TD></TR></TABLE>The k24 block is naturally taller because of 99 mm stroke than its k20 little brother, which i forget how big is the stroke on the k20, but surely smaller stroke though
can you snap some more clear pics of what you did to "make the rollbar work with the swaybar?" that one pic wasnt too clear and im curious as to what you did. good build projections!
It will not fit underneath the hood...... not even an SIR style one.
sell that rollbar and get an autopower if you plan on roadracing....the way the rear supports are centered closer to the middle of the car and are bent makes it weaker(those rollbars are meant for drag racing)...other than that sounds like a good build...o and wtf are nexan tires?
XJamesX
169
Jul 24, 2007 05:22 PM
