Oil light ON at idle?
Old May 31, 2008 | 09:46 PM
91EF_Si's Avatar
Default Oil light ON at idle?
I changed my oil pan gasket, oil, and filter today. And now oil light comes on only at idle, turns off when i pass 1k rpm. Still has a slight oil leak from the oil pan like it always had, but it never turned on the oil light. Oil is fine, i checked it when it was cold and hot. Also when it drops to idle, the rpm drops to about 500 and a weird noise sounds then gets back up to 800k and no noise.
97 ls motor with 113k miles, I have no idea if the oil pump is new or still oem stock.
smetzger
Dec 27, 2016 03:16 AM
91EF_Si
Jun 1, 2008 11:56 PM
awdgsx96
Nov 9, 2007 11:44 AM
GraphiteMW
Sep 2, 2007 11:07 AM
Poop111444
Aug 7, 2004 06:22 PM
