WHAT TO CHOOSE SKUNK OR TODA(HELP) Need YOUr INPut
So I have come down to my camshafts. Im building my ALL Motor. Whats best or whats really good between the two or i mean four???
First:
SKunk 2 pro series 2 vs the Pro series 3
Stage 2
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Stage 3
INTAKE lift- 12.7 mm, duration 273 @ 1mm
EXHAUST lift - 11.5 mm, duration 273 @ 1mm
Whats best for me to use between those two if i want a daily driver but with power?
then i have the toda cams to figure out to if the can do the same damage as the skunk2 cams. What do you think?
Toda spec 2 vs toda spec c cams
Toda B's
INTAKE lift - 12 mm,duration - 255 @ 1mm
EXHAUST lift - 12 mm, duration - 245 @ 1mm
Toda C's
INTAKE lift - 12.5 mm,duration - 255 @ 1mm
EXHAUST lift - 12.5 mm, duration - 255 @ 1mm
So whats better? Toda or Skunk2? I also hear the toda spec c cams are very aggressive and is able to snap the timing belt here and there? is that correct?
Please if you have knowledge to these cams or input for this...HELP ME OUT
Thanks HT.
First:
Stage 2
Stage 3
Toda B's
Toda C's
Thanks HT.
Wrong forum dude, and a lot of it depends on the amount of compression your planning to run, the displacement of the motor, if there will be any head work!! Make sure you state that when you have this thread moved to the correct place!! Or they WILL chew your ***!!
hrs-parker
May 31, 2008 09:31 PM
QB21
Oct 10, 2005 11:14 AM
