port and polished b16 head/intake
Well after months of drooling while cruising ht, I have decided to start putting together a budget to build out my b16 for road racing/autocross. This is the first time I have done something like this so please bear with me. I haven't spec'd bottom end out (prolly go 11.5-12 cr), but want to go skunk2 stage2 cams and valvetrain. I was wondering what the cost of buying a ported/polished head and intake should cost. I see that there are many for sale in the marketplace. who are the good techs/shops to buy from? I want to keep this really reliable and has to run on pump gas (91-92 octane) when its not on the track as it will be a dd too.
was looking at the s300. i know its more than I need really, but the datalogging and pc connectivity are attractive for the price. On the track I will run what I can find. The local autocross track doesnt have any available, but 101 and 103 are available at one of the others for sure. I dont really have a place to store drums, so i work with what I can get.
thot about it, but i have the sirII now. its still a good platform to start with, so the swap isnt worth it. would my header even bolt up? I did a block to tip exhaust a short while ago.
corect but you would put your vtec head on that block......etc
more torque and hp across the board
if your car is a d/d then you could build the short block with little or no down time
I have heard bad things with regards to reliability of those. head gaskets i think it was. I dont know if everyone just does them wrong around here, but I do need a reliable hwy car. I have an 800mi trip I do back and forth a couple times a month. a blown head in the mountains does not sound like fun. I was toying with getting another eg and doing that, but not the sol.
look man honestly stick to built b16.. if you buy a b20 block you have to balance pistons/rods/crank just to be safe since you're going to be in high rpm 99% of the time until you get flagged..i road race myself and dumped a ITR motor into my car lately since the ITR originally was built for road racing and the motor was factory built to handle high rpm (9000RPM) and beating for many hours..just check your oil
IMO just buy a ITR motor.. hytech race header,buddyclub spec 2 exhaust, 3" short ram intake with BLOX velocity stack/filter.. i put down 187whp/132tq.. good enough power for autocross/road racing..recently i street tuned on crome with skunk2 cam gears and I'm not sure how much power im putting down now, but ill hit the dyno soon
Modified by Fat Chick Magnet at 7:08 AM 6/2/2008
The Arp
Aug 18, 2010 08:00 AM
bt redliner
Sep 17, 2005 07:48 PM
