superwhite bulbs for my amber corners?
will superwhite bulbs look good for my amber corners? i have no pics cause im expecting the headlights to come in this monday. but yea they are for a 96 civic black housing with amber corners where the turn/parking light goes. the question is if i use superwhites for where my ambers are supposed 2 be would that turn out hella "amber" or would it be not as "amber" like if i bought amber bulbs? can somone show me a picture on how it would look? thankss
umm, whats the point?
all you are going to see is amber... and its not going to be brighter...
only use super white bulbs in your reverse lights, city lights or license plate lights ...
super white, is just a blue tint that makes the color of the light look "cooler" (as in temperature)
its not actually brighter...
I recently bought clear housings for my integra for my turn signals, and still have the stock 1157 and 194 white bulbs; which looks like a soft soft yellow. Aka garbage.
I'm looking into getting brighter bulbs, and basically have the same question.
In regards to LED's..
White? "Bright" White?
Or should I go Amber?
I want a bright, solid color. Not a soft light behind an amber shield. Are amber LED's bright and crisp?
Also, I know my stock 1157 bulb has the two coils inside to provide a 'low' and 'high' type light (for running light, and blinker when its on).. Do LED's have a secondary, higher light intensity? Or would it not flash when my blinker is on like the oems?
I also plan on getting clear-housing tail lights.
Suggestions in regards to lighting in those?
Any help is appreciated.
Modified by friesx100 at 4:32 PM 6/5/2008
If you get the proper High intensity LED bulbs they are just as bright as stock and yes you can get dual intensity ones as well....I run them in my orange crystal front corners and they are awesome. Actually Every light in my car is LED and they are all daylight visible, and look way better than stock bulbs.
msinsky14
Jul 27, 2006 06:12 PM
