car wont start need help.
Old May 31, 2008 | 09:06 PM
miguel329's Avatar
Default car wont start need help.
i have a 95 civic hatch with a gsr swap.. i was driving home on the feeway and the car shut of while i was driving.. well she cranks wont turn over so i bought a new ignition coil and it started rite up. i figured id give it time to warm up about 2 minutes after it was running it shut off againg.. now its do the same thing it was doing can someone please help me.
Old Jun 1, 2008 | 06:25 AM
miguel329's Avatar
Default Re: car wont start need help. (miguel329)
bump.............................................. .................................................. .....
Old Jun 1, 2008 | 07:39 AM
heavyhittersclub's Avatar
when it shuts off, will it start back up again now that the coil has been changed, Couple things i can think of that are easy to check and you can eliminate them early is your Neutral saftey switch, Take the connector off is there power and ground is the connector corroded, Other thing Wiggle the Ignition switch and test the Wires. The other things i can think of is Check your Plugs/wires/cap and clean your throttle body and IAC and TPS knock sensor maybe you will find somthing obvious like a connector slipping off.....If still nothing there Check your Tensioner for your Timing belt maybe the timing belt is missing some teeth here and there?
Old Jun 1, 2008 | 07:42 AM
Default Re: car wont start need help. (heavyhittersclub)
Check your Body Grounds aswell... Make sure the batt/alt 100%
Old Jun 1, 2008 | 12:29 PM
miguel329's Avatar
checked all that went to autozone got new distributor and everything works thanks! wish i could have more down time to afford oem but work on monday and need the car... thanks alot guys
Garcia505
14
Jul 10, 2013 06:23 PM
gamble01
Apr 24, 2013 06:37 AM
prelude504
Sep 7, 2009 03:19 PM
The Collin
10
Jun 17, 2008 12:31 PM
94_CRVtec
Jan 6, 2005 11:48 AM
