SKUNK2 PRO 2 OR PRO 3 vs TODA SPEC 2 OR 3
So I have come down to my camshafts. Im building my ALL Motor. Whats best or whats really good between the two or i mean four???
First:
SKunk 2 pro series 2 vs the Pro series 3
Stage 2
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Stage 3
INTAKE lift- 12.7 mm, duration 273 @ 1mm
EXHAUST lift - 11.5 mm, duration 273 @ 1mm
Whats best for me to use between those two if i want a daily driver but with power?
then i have the toda cams to figure out to if the can do the same damage as the skunk2 cams. What do you think?
Toda spec 2 vs toda spec c cams
Toda B's
INTAKE lift - 12 mm,duration - 255 @ 1mm
EXHAUST lift - 12 mm, duration - 245 @ 1mm
Toda C's
INTAKE lift - 12.5 mm,duration - 255 @ 1mm
EXHAUST lift - 12.5 mm, duration - 255 @ 1mm
So whats better? Toda or Skunk2? I also hear the toda spec c cams are very aggressive and is able to snap the timing belt here and there? is that correct?
Please if you have knowledge to these cams or input for this...HELP ME OUT
Thanks HT.
First:
Stage 2
Stage 3
Toda B's
Toda C's
Thanks HT.
im build my head right now..motor is getting sleeved..with wiesco 12.5:1 manley rods acl race bearings..etc..but my head is starting its build..so i need to figure out which one is better..toda or skunk and is so which ones??
hrs-parker
Jun 1, 2008 03:29 PM
QB21
Oct 10, 2005 11:14 AM
vtecjj
Dec 15, 2002 10:30 PM
