eg fog lights need help
hey i hear that u could put the lexus is300 fog lights on the eg but how do i do that? can any one help me or show me how with pics..
Modified by eg-6 life at 11:52 AM 6/1/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe »</TD></TR><TR><TD CLASS="quote">BUMP i wanna see this</TD></TR></TABLE>
BUMP BUMP BUMP
BUMP BUMP BUMP
You have to unscrew the OEM fog projector from the bracket, and then put the Is projector in the same spot. You will have to dremel 1 corner off the IS projector. Its really easy to mount to the bracket. The hard part is getting the bumper cover to fit back on, its takes some sheet metal removal on the frame rails(some sawzalling and hammering). Its not that hard to do, alittle time consuming, but worth it they have a much better out put than the OE civic fogs. This is for an IS fog with 9006 bulbs by the way, if you get the H3 version its probably not even worth it to do the mod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e46civic »</TD></TR><TR><TD CLASS="quote">You have to unscrew the OEM fog projector from the bracket, and then put the Is projector in the same spot. You will have to dremel 1 corner off the IS projector. Its really easy to mount to the bracket. The hard part is getting the bumper cover to fit back on, its takes some sheet metal removal on the frame rails(some sawzalling and hammering). Its not that hard to do, alittle time consuming, but worth it they have a much better out put than the OE civic fogs. This is for an IS fog with 9006 bulbs by the way, if you get the H3 version its probably not even worth it to do the mod.</TD></TR></TABLE>
^ Yeah. I've seen it a couple times and although it is very well time consuming, definitely worth it in the end.
Hellnoitsalex
Oct 15, 2009 05:08 PM
Jo$e L@go
Sep 29, 2009 06:21 PM
