JDM GSR BUILD UP
***IS THIS A GOOD MOTOR SETUP*** ??
-wanna put blueprint stage 2 cams, blueprint valvetrain, ITR pistons in my gsr without porting or polishing.
-would it be safe to run without the port and polish job
-has anyone experienced with these blueprint products i only hear good stuff willing to try
***should i stick with the blueprints or should i go with crower ? would the ITR pistons be good or should i go with something else...this is a daily driver so i dont want the compression too high. the next step after all the parts is a good tune..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rheg6 »</TD></TR><TR><TD CLASS="quote">
you mean bore/hone? your new rings might not seal good so may burn oil.
-has anyone experienced with these blueprint products i only hear good stuff willing to try</TD></TR></TABLE>
wtf is blueprint?
wtf is blueprint?
blueprints are good **** .. people around here making good numbers with blueprint parts..you should look into it more and research .. blueprint is prolly the new **** on the block
my old gsr set up
stock bottom block
stoch head with sk2stg2 cams
blox valve springs and retainers
hytech replica headers
skunk 2 manifold
exedy stage 1 clutch
clutch master light flywheel
type r tranny lsd 4.4 fd
p28 ecu w/ s200 hondata
my best time with this set up is 12.9 1/4 mile w/ 22's slicks
stock bottom block
skunk 2 manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rheg6 »</TD></TR><TR><TD CLASS="quote">-would it be safe to run without the port and polish job</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rheg6 »</TD></TR><TR><TD CLASS="quote"> would the ITR pistons be good or should i go with something else..</TD></TR></TABLE>
ITR's are a good choice for you saying:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rheg6 »</TD></TR><TR><TD CLASS="quote">this is a daily driver so i dont want the compression too high</TD></TR></TABLE>
Choose a good intake/IM/header and..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rheg6 »</TD></TR><TR><TD CLASS="quote">***IS THIS A GOOD MOTOR SETUP*** ??</TD></TR></TABLE>
Yes. I <U>think</U> the BP "stage2" is similar to the S2S2, I don't know much about their camshafts but they do build quality product. I also believe that Jeff at Import Builders has something to do with this, B19coupe might be able to shine some light here
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rheg6 »</TD></TR><TR><TD CLASS="quote">blueprints are good **** .. people around here making good numbers with blueprint parts..you should look into it more and research .. blueprint is prolly the new **** on the block</TD></TR></TABLE>
no offense man, but this is the most hilarious post ive ever seen! ftw!!! keep up the good work
LvN
Sep 20, 2006 01:43 PM
boostin4door
Jan 30, 2005 08:40 PM
