Need help with right size trottle body fof my SiR
Old May 31, 2008 | 02:39 PM
ajhemp's Avatar
Default Need help with right size trottle body fof my SiR
Whats the best size trottle body to run on my ek4 SiR, i was told that a type r civic would be the best but im not to sure......can anyone help.....thanks
Old Jun 2, 2008 | 12:16 PM
lk5545's Avatar
Default Re: Need help with right size trottle body fof my SiR (ajhemp)
the best size throttle body to run on your sir i would recommend a integra type r 62mm
Old Jun 3, 2008 | 11:38 AM
ajhemp's Avatar
Default Re: Need help with right size trottle body fof my SiR (lk5545)
Are you sure about that now.....coz i was going to put a 70mm off a mini on it.....!!
Old Jun 4, 2008 | 01:51 AM
lk5545's Avatar
wouldnt do that the mini would miss it to much
Old Jun 4, 2008 | 03:30 AM
ddd4114's Avatar
Assuming the engine is stock, 60mm.
Old Jun 12, 2008 | 04:27 PM
ajhemp's Avatar
Default Re: Need help with right size trottle body fof my SiR (ddd4114)
Yeah the engine is stock, but with a skunk2 intake and out take manifold, with a straight through on it to.....can i put any bigger than a teg type r 62mm on it for more gains.....and will i get and feel much more of a gain from it.....?
Old Jun 12, 2008 | 04:42 PM
ddd4114's Avatar
I'm honestly not sure how the plenum volume of the Skunk2 manifold compares to that of the stock manifold. If you know for a fact that it's significantly smaller, then you can use a 62mm throttle body. Otherwise, it's pointless.
You may feel more "power" with a larger throttle body, but it's just an illusion. You have a larger aperture compared to the stock throttle body at the same throttle position. If you want the same effect, replace the throttle rotor instead. You can also just push the throttle down further.
Modified by ddd4114 at 12:42 PM 6/15/2008
Old Jun 15, 2008 | 08:44 AM
ddd4114's Avatar
I just realized that I posted the opposite of what I was thinking, and it's just been corrected (see previous post). I don't know why it took me 3 days to realize this....
larger plenum, smaller throttle body
smaller plenum, larger throttle body
92_civic_lx
Sep 4, 2008 02:09 PM
hmgemperor2003
Sep 16, 2007 10:16 AM
LU
Nov 10, 2006 10:54 PM
Project_Civic
Apr 3, 2005 12:23 PM
wushubrian
Jan 26, 2005 07:23 PM
