Foglight Switch Location
Old May 31, 2008 | 08:38 AM
ekuurantegwa's Avatar
Default Foglight Switch Location
I am trying to find the OEM location of the Foglight switch on 98+ integras equipped with Cruise Control and Foglights.
I want to keep the ITR front end swap as clean as possible, and put the switch in the OEM location for the US integra dash.
Picture would help, thanks in advance
Old May 31, 2008 | 11:25 AM
BlueIntegraBoy's Avatar
Default Re: Foglight Switch Location (ekuurantegwa)
It goes in one of the blank panels on your armrest console.
Old Jun 4, 2008 | 09:01 PM
dc2teg06's Avatar
Default Re: Foglight Switch Location (BlueIntegraBoy)
If your referring to the switch located in the arm-rest, here are some pics of the switch:
Installed in my USDM armrest:
Close Up:
Old Jun 5, 2008 | 08:50 PM
XslickwhitetegX's Avatar
Default Re: Foglight Switch Location (dc2teg06)
actually the foglight switch that goes in the arm rest is for 94-97 tegs, believe its SI Vtec fogs or sirg fog but it will also work for 98+ ones.. there's aso another location for the 98+ oem fogs(also includes itr) and that's located where the dimmer switch is for the cluster.. either one you can keep your cruise controls!
Old Jun 5, 2008 | 10:06 PM
Default Re: Foglight Switch Location (XslickwhitetegX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XslickwhitetegX &raquo;</TD></TR><TR><TD CLASS="quote">actually the foglight switch that goes in the arm rest is for 94-97 tegs, believe its SI Vtec fogs or sirg fog but it will also work for 98+ ones.. [b]there's aso another location for the 98+ oem fogs(also includes itr) and that's located where the dimmer switch is for the cluster.. either one you can keep your cruise controls![b]</TD></TR></TABLE>
This is incorrect. My brand new fog kit (98-01) came with the switch above. The switch on the dash is JDM.
Old Jun 6, 2008 | 12:26 AM
alltech.magoo's Avatar
i like the location of the fog switch on the armrest.
Old Jun 6, 2008 | 08:28 PM
dc2teg06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XslickwhitetegX &raquo;</TD></TR><TR><TD CLASS="quote">actually the foglight switch that goes in the arm rest is for 94-97 tegs, believe its SI Vtec fogs or sirg fog</TD></TR></TABLE>
That would be the fog light switch that would replace the cruise control switch on JDM model integras. I believe they also used those to for the UKDM rear foglights, although I'm not sure, nor does it matter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
This is incorrect. My brand new fog kit (98-01) came with the switch above. The switch on the dash is JDM.</TD></TR></TABLE>
Correct, the 98+ USDM Integras that came with optional fog lights were equipped with the switch that I have pictured that is located in the arm rest.
With that in mind, it doesn't really matter what switch you use. If your wiring up a new set of fog lights, the switch doesn't really matter. Either will pretty much work for any application. I have a 98+ USDM foglight switch running my 94-97 Si-Vtec fog lights. It's mainly just a preference issue on switch location. If your considering the JDM switch, and your car is equipped with cruise control, you will have to choose whether or not you want that option in your car. Although I'm not sure, it was stated you could use the JDM switch in place of the dimmer, which would allow you to keep the cruise control switch. There are so many wiring options, it doesn't matter at all which switch you choose, the only thing that matters is that it is done right, and is fully functional.
Old Jun 6, 2008 | 08:39 PM
dc4_wHORE's Avatar
Soldering Iron Wizardry
i bought an OEM foglight kit for my 2000 teg, and it came with the same arm rest switch
Old Jun 6, 2008 | 11:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2teg06 &raquo;</TD></TR><TR><TD CLASS="quote">Although I'm not sure, it was stated you could use the JDM switch in place of the dimmer, which would allow you to keep the cruise control switch. There are so many wiring options, it doesn't matter at all which switch you choose, the only thing that matters is that it is done right, and is fully functional.</TD></TR></TABLE>
You would have to find a way to tuck the dimmer switch behind the dash plugged in.
I am running the JDM switch in my R with the 98-01 optional fogs and harness. Of course, the R's don't come with cruise, so it's in the cruise control switch location.
Old Jun 7, 2008 | 06:17 PM
really meow? I've always seen the 98-01 fogs w/ the round button on the dash, never seen them with center console.. so I guess only ITR models came with the the button on the dash? interesting I finally learn something on HT.. LOL
Old Jun 7, 2008 | 06:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XslickwhitetegX &raquo;</TD></TR><TR><TD CLASS="quote">really meow? I've always seen the 98-01 fogs w/ the round button on the dash, never seen them with center console.. so I guess only ITR models came with the the button on the dash? interesting I finally learn something on HT.. LOL</TD></TR></TABLE>
Only JDM models had the round switch. Everywhere got the center console switch.
Old Jun 15, 2008 | 10:23 AM
JDM_CRX_PLEASE's Avatar
um no... for 1994-97 integra the fog light switch goes on the dash. its located on the other side of the lumination dial. it comes with a blank peice instead of an actual button.
the integra RS comes with a blank peice instead of an actual button for any use. its round.
sorry no pics.
Old Jun 15, 2008 | 01:09 PM
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">um no... for 1994-97 integra the fog light switch goes on the dash. its located on the other side of the lumination dial. it comes with a blank peice instead of an actual button.
sorry no pics.</TD></TR></TABLE>
The RS and ITR came with a cruise control switch blockoff plate, but it doesn't mean the 94-97 Integras came with the dash switch. They came with the console switch like every other non-JDM Integra.
To correct my post above, only the JDM models had the round front fog light switch. Europe had the round rear fog light switch on the dash.
Old Jun 18, 2008 | 06:58 PM
Default Re: (BlueIntegraBoy)
To correct my post above, only the JDM models had the round front fog light switch. Europe had the round rear fog light switch on the dash.</TD></TR></TABLE>
i get what your saying, you can put the foglight switch on the center consol but id rather put it on the dial thats on the dash. JDM button ftw.
Old Jun 18, 2008 | 10:04 PM
SuckMyDOHC's Avatar
i get what your saying, you can put the foglight switch on the center consol but id rather put it on the dial thats on the dash. JDM button ftw.</TD></TR></TABLE>
Doesn't seem like you get what he's saying. The switch that goes on the center console is what comes with the foglights. Go ahead and try putting that on your dash where the JDM fog light switch goes. You'd have to go out and buy the JDM fog light switch along with your USDM fog light kit, which I will agree that it does look better.
Old Jun 21, 2008 | 12:53 PM
mackyxl's Avatar
Default Re: (SuckMyDOHC)
to make this easy... Only the 96-00 JDM-UK- or whatever RECARO equipped ITR comes with a fog light switch that goes in the dash. Or in other words, any stock ITR equipped with this.
Old Jun 21, 2008 | 02:00 PM
instead of cruise control button, its a fog light button in any itr.
Old Jun 21, 2008 | 02:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">
Doesn't seem like you get what he's saying. The switch that goes on the center console is what comes with the foglights. Go ahead and try putting that on your dash where the JDM fog light switch goes. You'd have to go out and buy the JDM fog light switch along with your USDM fog light kit, which I will agree that it does look better.</TD></TR></TABLE>
thats what i ment -_-. the jdm fog light switch looks better to me imo instead of the square one that goes on your center console. i hate the center console fog square button. its ugly to me
Old Jun 21, 2008 | 02:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">instead of cruise control button, its a fog light button in any itr.</TD></TR></TABLE>
In the UK/Europe, the rear fog switch takes the place of the dimmer switch, not the cruise switch.
Old Jun 24, 2008 | 06:44 PM
Thorgs's Avatar
I don't mean to hijack the thread but does anyone know the part number to the 94-97 fog light kit?
Old Jun 27, 2008 | 08:19 PM
Thorgs's Avatar
Default Re: (Thorgs)
Anyone know?
Old Jun 29, 2008 | 12:52 AM
mackyxl's Avatar
08V31-ST7-201
Old Jun 29, 2008 | 07:48 AM
Thorgs's Avatar
Default Re: (mackyxl)
I think that's just for the foglight. Not for the kit. And that's for 98-01. Thanks though.
Old Jun 29, 2008 | 12:45 PM
Naruto's Avatar
Your question has been answered here:
https://honda-tech.com/zero...age=3
Old Jun 29, 2008 | 04:26 PM
Lro255's Avatar
Default Re: (Naruto)
Just to give you some idea I have two fog lights, and I also have two fog light switches.
For my front UKDM fog I use the UKDM/JDM fog Switch.
For the rear UKDM/JDM fog light I use the USDM fog switch.
