F20B in Ef
Old May 31, 2008 | 08:31 AM
Cestparti's Avatar
Default F20B in Ef
How difficult would it be to install an F20B in an EF. Has anyone done it before? Cause im looking in to it and I want to know around how much it would cost to install it?
Thanks
Old May 31, 2008 | 08:52 AM
Voodooboy520's Avatar
F series have the same mounts as H series, so hard.
Old May 31, 2008 | 10:29 AM
-SkInNy-'s Avatar
Default Re: F20B in Ef (Cestparti)
i don't think it would be as hard as an h22
Old May 31, 2008 | 10:48 AM
Jonknee's Avatar
Default Re: F20B in Ef (-SkInNy-)
I always wanted to do one, but it looks expensive for what it is.
Old May 31, 2008 | 11:37 AM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -SkInNy- &raquo;</TD></TR><TR><TD CLASS="quote">i don't think it would be as hard as an h22</TD></TR></TABLE>
The blue valve cover dosen't make it fit any easier.
Externally theres no difference between the H22A vs F20B. <FONT COLOR="red"><u>Search</FONT></u> (for anything related to F or H series in an EF) and you'll find all the info you could ever possibly need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">F series have the same mounts as H series, so hard.</TD></TR></TABLE>
Old May 31, 2008 | 12:34 PM
89CRXProject's Avatar
CTR, ITR, GSR, b16a
only motors that belong in our 1900lbs cars in my opinion
Old May 31, 2008 | 04:47 PM
CRX Toad's Avatar
What? It is essentially the same swap not hard or easier.
Old Jun 3, 2008 | 09:43 AM
bdp's Avatar
bdp
* B A N N E D *
Default Re: F20B in Ef (CRX Toad)
bump for more info.
Old Jun 3, 2008 | 10:03 AM
crxhondata's Avatar
i was i thinking the same think yesterday because me and my brother went to see a accord for car dealer and see the engine was thinkiing if will fit in my crx nice question
Old Jun 3, 2008 | 10:04 AM
K2e2vin's Avatar
Default Re: (89CRXProject)
In my opinion; only D-series belong in our 1900lb FWD cars
There's no other info needed; it's the same as a H22A swap. If you're searching for a write-up; just look up H22 into EF.
Old Jun 3, 2008 | 11:47 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Here's a good question... does the f20b suffer from the same problems that the h22a head has? IE ridiculous rocker pad wear and the few other issues that have arisen with h22a heads?
Old Jun 3, 2008 | 11:55 AM
SIred91's Avatar
Rainman
Default Re: (K2e2vin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2e2vin &raquo;</TD></TR><TR><TD CLASS="quote">In my opinion; only D-series belong in our 1900lb FWD cars
IMHO, the D series should be in all models except the Si. The B16 was made solely for that car.
Old Jun 3, 2008 | 12:04 PM
gibsanez's Avatar
I'm not a fan of the cable shifted transmissions or their gear ratio's so if it was any other forum I would suggest H2B. But since this is a 4th gen forum, I'd say just go B series.
H/F mounts are expensive too
Old Jun 4, 2008 | 05:10 AM
ComeOnKip's Avatar
Default Re: (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">I'm not a fan of the cable shifted transmissions or their gear ratio's so if it was any other forum I would suggest H2B. But since this is a 4th gen forum, I'd say just go B series.
H/F mounts are expensive too </TD></TR></TABLE>
Seeing as how you're pretty familiar with the H/F, do you know the answer to...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">Here's a good question... does the f20b suffer from the same problems that the h22a head has? IE ridiculous rocker pad wear and the few other issues that have arisen with h22a heads?</TD></TR></TABLE>
Old Jun 4, 2008 | 06:22 AM
gibsanez's Avatar
Default Re: (ComeOnKip)
The heads are pretty much identical, but I haven't seen read or seen enough from the F20B to know if they suffer the same fate or not.
Old Jun 4, 2008 | 06:29 AM
ComeOnKip's Avatar
Intriguing. It doesn't seem like its dime-a-dozen enough like an h22a to have alot of view on exh. rocker pad wear.
elf469
39
Oct 14, 2008 04:16 AM
whiteguyndahood
Nov 9, 2007 07:45 PM
jdmjoelol
38
Jan 24, 2006 03:32 PM
arjay702
Aug 18, 2005 10:41 AM
