Rear driver's side quater panel
Old May 31, 2008 | 08:20 AM
Zerophase's Avatar
Default Rear driver's side quater panel
I have a 94 Accord LX and the hole that hold the bumper up on the rear driver's side quarter panel has rusted a bit and the hole has broken.I've never welded anything ever but I have an idea to fix this problem.I was thinking about going to the junk yard and having a small section cut out from another Accord and have a buddy who welds,cut and patch it onto my car.Being that it's one big whole piece that runs along the top all the way up to the windshield,I figured that patching a piece would be easier that having the whole thing replaced.
I don't know if this is a common thing to do,but common sense would tell me that someone who knows what the hell they are doing wouldn't have that much or a problem with this.Am I on track of somewhat off base?After grinding the welds and repainting,it should come out o.k.,right?
Old Jun 1, 2008 | 08:52 AM
Zerophase's Avatar
Default Re: Rear driver's side quater panel (Zerophase)
bump
Old Jun 3, 2008 | 07:23 PM
digdug18's Avatar
i just got laid off from a junk yard and what your describing is a common problem, but you cant just get a small piece, a junk yard will sell you the whole rear quarter, think about $200-$300 depending on if you cut it or if they cut it.
I do however give you a cheaper option, you could just cut out the corroded material, and weld in a piece of steel, paint it quickly and use a crap load of bondo/filler to smooth the area. It will only cost about $50 for materials, it'll just take alot longer to get it smooth and upto par for that area is all, alot of elbow grease...
Andrew
Lastgsr
Aug 7, 2008 07:29 AM
istabrak
Sep 27, 2005 10:48 AM
James
Feb 7, 2005 04:47 PM
integraautox
Nov 12, 2002 04:18 PM
