haywire in tach?
Old Jul 16, 2002 | 08:46 AM
Ya@inlinePRO's Avatar
Default haywire in tach?
my sister got a 97 accord, not modified or nothing, just bone stock, the v6, recenetly the tach has been jumpin, like the rpm needle goes up and down randomly? any ideas about the reason behind this? i think its just the sockets loose or what not, but the car doesn't JUMP wit it, so i know the engine is ok, just some electrical, thanks for the help
Old Jul 16, 2002 | 09:09 AM
YeuEmMaiMai's Avatar
Default Re: haywire in tach? (kwik2nec)
check for a loose electrical connection on the tachometer circuit. the plug on the instrument cluster and at the distributor and check ground. if all is good replace the tach
Old Jul 16, 2002 | 02:15 PM
Chiovnidca's Avatar
Is your CEL on also? There is a resister in the ignition coil that can cause the tach to jump, but they usually also trigger the CEL. I can't recall the code.
bill-71SS's Avatar
check you igniter in dist. could be bad,the blue wire is for tach.
Old Jul 16, 2002 | 03:17 PM
iight i'll have a check as soon as i can.
badmrb
Nov 22, 2015 08:52 AM
ChevelleSSLS6
Nov 14, 2009 05:51 PM
frostee trooper
Feb 6, 2005 10:58 PM
rice is nice
Dec 7, 2004 10:26 AM
ineedmoney
Jul 28, 2004 07:50 AM
