crank question
Old May 30, 2008 | 10:50 PM
SiR Inspired ED7's Avatar
Default crank question
Its a Ls Block with p30 p25 over pistans, Ls rods z10 billit girdle, the short block is assembled within torque specs and when i try to rotate/spin the pulley by hand its tight is it normal for it to be tight if i was trying to spin it with my hand? The block had spun bearing # 3 and where replaced with standard acl bearings torqued to specs and i replaced the crank made sure it was straight and got it repolished. The head was not bolted on when i tried spinnig the pulley it was just the short block. One shop told me that it was bad and another shop told me that it was normal input is appreciated thanks
Old May 30, 2008 | 11:20 PM
4g hatch's Avatar
Default Re: crank question (SiR Inspired ED7)
if the rods are not attached then it should spin free. if they are then it will have some resistance. is it alot.
Old May 31, 2008 | 04:17 PM
Default Re: crank question (4g hatch)
With out the rods it was kind of hard to spin by hand... I plastigauged all the journals & they were .0015 on all of them.
Old May 31, 2008 | 05:24 PM
frostyrb's Avatar
Did you spin a rod bearing or main bearing. If you spun a main bearing was the crank replaced & was the block line honed? Also why did the bearing spin? Wrong clearences? Low oil?
Old Jun 1, 2008 | 12:09 PM
Default Re: crank question (frostyrb)
Yes it did spin bearing #3, it was cause the shop that did my block had put the piston rings upside down & it would burn alot of oil.
Old Jun 1, 2008 | 12:23 PM
4g hatch's Avatar
you may need a line hone. i wouldnt assemble it like that
Old Jun 1, 2008 | 12:26 PM
They do that in any machine shop right.
Old Jun 1, 2008 | 12:43 PM
4g hatch's Avatar
yep,but i wouldnt use the shop that installed your rings upside down
Pandahatch
28
Feb 27, 2006 08:08 PM
Pandahatch
Feb 26, 2006 10:08 AM
CBURKE
Jan 9, 2006 06:51 AM
SpeedDreamz.com
May 19, 2004 08:34 PM
