My first dyno plot with the Drag III installed.
Old Jul 16, 2002 | 08:37 AM
RATEDR's Avatar
Default My first dyno plot with the Drag III installed.
I posted my air/fuel plot on the FI board...dont know if any of you saw it. Basically my car needs fuel BAD! But besides all that I feel good about the car and how it runs...just gotta get the fuel issue taken care of.
The plot is layed over my BONE stock plot so you can see the difference. You will also see on the turbo plot that it only goes to 7400 rpms. At that point the J&S was going crazy and retarding the timing by over 14 degrees so I let off the throttle.
This was just a baseline, no tuning, no fuel pressure riser, no V-AFC, nothing but a 12:1 FMU and inline fuel pump. Car is running 6psi.
the numbers say 159.9hp with 112.7tq stock
205.8hp with 151.1 at 7400 rpms untuned.
both my stock run and turbo run were done in 4th gear.
[Modified by RATEDR, 12:53 PM 7/16/2002]
Old Jul 16, 2002 | 08:38 AM
Rob :190:'s Avatar
Default Re: My first dyno plot with the Drag III installed. (RATEDR)
what all are you going to tune with?
looks good for a base run
Old Jul 16, 2002 | 08:39 AM
done's Avatar
get those bugs worked out... youll see tons of power....
save for a standalone
Old Jul 16, 2002 | 08:40 AM
RTW DC2R's Avatar
I hope u can pull lots more power after you get her tuned. I would not be happy with only 205hp or so with a turbo setup. did you keep your stock bottom end or lower the compression?
RATEDR's Avatar
Default Re: My first dyno plot with the Drag III installed. ( Rob)
I have RC 550 injectors on order as well as a AEM EMS standalone.
Car is completely stock (internals and compression)
[Modified by RATEDR, 12:41 PM 7/16/2002]
Nate B's Avatar
Not too bad, just feed that motor some fuel and you should be good. Good luck
Old Jul 16, 2002 | 08:41 AM
Rob :190:'s Avatar
Default Re: My first dyno plot with the Drag III installed. (KILLERB18)
let us know how the AEM EMS works out, I'm sure a lot of people are very interested to hear
Old Jul 16, 2002 | 08:42 AM
Dave-ROR's Avatar
HELL YEAH!
-Dave, who says **** NA, B00ST 0WNZ!
Old Jul 16, 2002 | 08:49 AM
Big Phat R's Avatar
The wavy part of your dyno plot looks scary - but otherwise
you might also want to consider upgrading the engine mounts and LSD - or else you are never gonna be able to hook up your blown ****. I heard those Z-10 traction bars are also a worthy upgrade
Old Jul 16, 2002 | 08:52 AM
RATEDR's Avatar
Default Re: My first dyno plot with the Drag III installed. (Phat Bastard)
Yeah that wavy part is why im not driving the car until the AEM comes in. Its been parked since the dyno runs. As soon as the fuel thing is taken care of I will then start upgrading other things such as clutch, mounts, etc etc.
Not sure if I stated this earlier either but this is at 6psi.
Old Jul 16, 2002 | 08:53 AM
Reid's Avatar
Global Moderator
Wow.
At 6 psi?
What fuel pump are you running? How many lph?
Old Jul 16, 2002 | 08:54 AM
B18CXr's Avatar
Boost rocks.........
tune that bitch
Old Jul 16, 2002 | 08:56 AM
austrian type-R's Avatar
WTF, you have installed a DRAG III kit which is supposed to run not bad with the stuff in the kit. You can not tune a stock DRAG III kit, cause the FMU has a fixed rising rate of 12:1. So why the hell does companys deal with kits, when you have to upgrade to get a safe setup?
Buy injesotrs, standalone, cam gears, ASAP 3" exhaust and you are the man!
[Modified by austrian type-R, 6:57 PM 7/16/2002]
Old Jul 16, 2002 | 08:57 AM
HybridKOOP's Avatar
How much boost were you running? And you said no fuel pressure riser, but 12:1 FMU?
RATEDR's Avatar
Default Re: My first dyno plot with the Drag III installed. (Reid)
Not sure the name...its the inline fuel pump that came with the DRAG kit. I have a Walbro 255l/hr high pressure for when I drop the AEM system in.
I have a custome 2.5" exhaust all the way back with mandrel bends and test pipe.
[Modified by RATEDR, 1:03 PM 7/16/2002]
Old Jul 16, 2002 | 08:59 AM
Reid's Avatar
Global Moderator
Default Re: My first dyno plot with the Drag III installed. (B18CXr)
How much hp/tq can he expect to see with this setup?
EDIT: the setup, as is, in its current state
[Modified by Reid, 7:59 AM 7/16/2002]
Old Jul 16, 2002 | 09:01 AM
HybridKOOP's Avatar
At 6 psi on the stock motor he should see about 225-230 whp.
RATEDR's Avatar
Default Re: My first dyno plot with the Drag III installed. (austrian type-R)
Yeah, but the Drag kit is good for something...its relatively inexpensive and comes with everything you need. If I had owned a V-AFC before hand then I could have tuned the car a bit and wouldnt really have that serious a fuel issue. The 12:1 FMU is doing its job I guess but its not enough or my injectors are maxed out...one or the other.
No fuel pressure riser meaning something like the AEM unit or Aeromotive or B&M...no way to increase the pressure all across the board. The Vortec 12:1 FMU comes with the kit.
[Modified by RATEDR, 1:04 PM 7/16/2002]
Old Jul 16, 2002 | 09:03 AM
HybridKOOP's Avatar
Then I doubt your injectors are maxing out without the general fuel pressure cranked up...
Old Jul 16, 2002 | 09:06 AM
RATEDR's Avatar
Default Re: My first dyno plot with the Drag III installed. (HybridKOOP)
Yeah, like I said Im sure with a FPR and v-afc I could get it more fuel...but I dont want to push the stock injectors to the max and worry about what could go wrong..ill invest in the 550s and standalone since I have a built block going in the car soon anyways and ill need these things.
Old Jul 16, 2002 | 09:07 AM
B18CXr's Avatar
you'll see 240ish with 6-7 pounds........
injectors are not "maxed"
rail pressure...yes, but not injectors.
your j&s needs "tweaking"
Old Jul 16, 2002 | 09:10 AM
Reid's Avatar
Global Moderator
If you need to keep:
stock bottom end
stock ECU
What's the best way to go about handling the fuel issue?
Old Jul 16, 2002 | 09:12 AM
HybridKOOP's Avatar
RatedR... do you still have the installation pics up on any servers? I'd like to take a peek again...
Old Jul 16, 2002 | 09:13 AM
vtecvoodoo's Avatar
Future Texas Boy
Buddy does 260/190 w/ 8lbs, vafc, and 3" exh on his gsr. One of the cleanest graphs you`ll see
[Modified by vtecvoodoo, 6:17 PM 7/16/2002]
Old Jul 16, 2002 | 09:14 AM
Reid's Avatar
Global Moderator
Default Re: My first dyno plot with the Drag III installed. (vtecvoodoo)
Buddy does 260/190 w/ 8lbs, vafc, and 3" exh. One of the cleanest graphs you`ll see
What are his V-AFC settings?
