---->need help with my b16.....please
have a problem and dont know wat it is
i have a b16a on my eg..and its waisting too much gas ($50 in to days)
i took out my spark plugs and there burn i put new ones and checked them
out and there burn
can some1 tell me wat it could be
thanks
everything is stock..nothing but a short ram
Modified by eg-6 life at 6:07 PM 5/30/2008
out and there burn
thanks
how in the world, can a bad fuel pump cause you to use too much fuel? any unused fuel by the motor, is pumped back to the tank via the RETURN LINE.
so id love to know how a bad fuel pump makes you use more gas?
Landon
Landon
is it running rough? how many miles on the engine? no cel? could be a # of things, are planning on fixing it yourself? cause u don't sound mechanically inclined
well i know my basics i do my owen swaps and if i new wat it was i would of fixed it but i need a lil bit of help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">is it running rough? how many miles on the engine? no cel? </TD></TR></TABLE>
also, check what the coolant temp. sensor and iat sensor are reading
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j3t1p »</TD></TR><TR><TD CLASS="quote">yo dude I go with the guy that said fuel pump... my buddy was in in the same boat as you were.
best of luck.</TD></TR></TABLE>
Nope. The car's running too rich. The fuel pump supplies volume. The FPR, injectors, and the ECU are the final determinants the amount of fuel actually going into the cylinder.
OP: Are there any check engine lights on?
My EM1 was getting shitty gas mileage as well. My problem stemmed from a bad fuel pressure regulator. I replaced it with one from a junkyard (D series) and the mileage numbers improved drastically. It only cost me $2 to fix.
Your problem could be 1 out of 200 billion things. Online sites are not a good way to get information about a vague and vast issue like this one. "Black spark plugs" usually mean the car is running rich. The REASON why it's running rich could be so many things that it would be impossible to E-fix a car that nobody on here has had the opportunity to actually diagnose.
Driveability issues like yours are sometimes hard to diagnose. If there is a CEL on, I'd start by checking there. From there, you'd have to have expensive computer equipment to accurately check everything.
Take the car somewhere. Have it checked out and save yourself a headache.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
thanks ima change the fpr and if is not that ima take it to a honda specialist,,,thanks..
do you speak or read english? i as well as at least 2 other posters have asked you if you have a CHECK ENGINE LIGHT on. and yet you dont answer, you dont seem like you want much help if you dont even answer our questions. good luck chief.
Landon
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg-6 life »</TD></TR><TR><TD CLASS="quote">and i said no and i changed the fpr and ijecters and fuil rail and its still doing that
Does your check engine light work? Does the bulb come on for a few seconds when you start the car?
I would stop throwing parts at it. The fuel rail has no effect if the injectors are stock as long as it's big enough to feed the stock injectors. Hope you didn't pay much for your new one.
</TD></TR></TABLE>Does your check engine light work? Does the bulb come on for a few seconds when you start the car?
