Temp gauge
When I'm at a stand still the Temp Gauge rises almost to the top and when I begin to move it returns to normal. What can be causing this problem? I have anti-freeze in the radiator.
1997 Civic EX sedan
1997 Civic EX sedan
well, you dont really have to drain it. just take the lower radiator hose off the motor where the thermostat is at. (anit-freeze will come out a little) then i think its 2 bolts thats holding on the thermostat.. take those off and you will see the thermostat after u take that housing off.
I think I can do it. Is it easier to access from under the car or from the hood? Also do I nee a special wrench or socket to remove the bolt? Thanks so much for helping me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJBBMANO »</TD></TR><TR><TD CLASS="quote">I think I can do it. Is it easier to access from under the car or from the hood? Also do I nee a special wrench or socket to remove the bolt? Thanks so much for helping me out.</TD></TR></TABLE>
yeah you cant work on it under the car. haha. under the hood is the way to do it. you need pliers, 10mm socket with a ratchet to take off the bolts and thats about it really. its easy. let me know how it goes. take pics if you have any problems
96_coupe
40
Apr 2, 2012 10:35 AM
