Who maks A LSD Kit For a J1 cable transmission
Old May 30, 2008 | 02:43 PM
Kid_SiR's Avatar
Default Who maks A LSD Kit For a J1 cable transmission
ive callled an confirm OBX dose not make a lsd kit for a cable tranny soo who else makes an lsd that will fit a cable tranny
Old May 30, 2008 | 03:14 PM
civickid03's Avatar
Default Re: Who maks A LSD Kit For a J1 cable transmission (Kid_SiR)
i'm pretty sure all cable b16 lsd's are interchangeable...you have to do some research to be 100%...you could get a spoon one but they are expensive as hell....quaife makes one im pretty sure...
Old May 30, 2008 | 11:53 PM
Janos Lin's Avatar
Default Re: Who maks A LSD Kit For a J1 cable transmission (civickid03)
u need the LSD9000 one from OBX.
Janos
Old May 31, 2008 | 03:06 AM
NlCK B's Avatar
i got a kaaz in mine
Old May 31, 2008 | 11:26 AM
Runnerdown's Avatar
all b16 and ls diff are interchangable.
Old May 31, 2008 | 01:35 PM
Kid_SiR's Avatar
ok janos u say get the obx 9000 i called them an they told me they dont make one are u sure it will fitt ...
Nick b u got a kazza lsd for ur cable how much did u pay for that
Old May 31, 2008 | 01:43 PM
Crx Jimmy's Avatar
Default Re: (Kid_SiR)
Off the top of my head I beleive ATS/Carbonetic, Kaaz, and Cusco make them for the cable Tranny
Old May 31, 2008 | 01:53 PM
shevlin's Avatar
Default Re: (Crx Jimmy)
any b16 a diff will fit, I ordered an obx for a 99-00 civic si and installed it in my s1 cable tranny, no problems what so ever
Old May 31, 2008 | 02:00 PM
Runnerdown's Avatar
EVERY B16A AND LS TRANNY CABLE OR HYDRO USE THE SAME DIFFERENTIAL.
How do I know, easy..I install differentials all the time and I know what works. Also, if you don't believe me look up the part numbers and see which ones are the same.
The following cars/tranny all use the same differential and all are interchangable.
99-00 civic si hydro
del sol vtec hydro
90-00 integra ls, gs, rs hydro or cable
92-93 gs-r cable
JDM 89-91 y1, s1, j1 cable
jdm y21 s21 hydro cvic sir2 hydro
There are more models I forgot but I think you will get the jist.
Old May 31, 2008 | 06:28 PM
Kid_SiR's Avatar
ok runnerdown ur saying i can order a obx lsd for a b16 hydro an it will fit my cable one if i understande wat ur saying
Old May 31, 2008 | 06:51 PM
Runnerdown's Avatar
Yes.
I have a J1 tranny in my car. I put a quaife lsd in.
Old May 31, 2008 | 06:56 PM
NlCK B's Avatar
i paid 750 threw a guy that had a hook up threw kaaz unfortunately his shop closed but the guys at kaaz in wesmister are very helpful if you have any questions they will gladly help you out i actually spent about an hour in there shop just kinda shooting the **** i'd call them up or stop by if you could
Old May 31, 2008 | 07:41 PM
Kid_SiR's Avatar
well i would get a quaife but not tryin too spend that money now i wanted too know if i can get a obx for now
Old May 31, 2008 | 07:57 PM
NlCK B's Avatar
are you planning on using this for drag or cornering(track, auto x,etc...)
Old May 31, 2008 | 09:06 PM
Kid_SiR's Avatar
im only gonna use it for drag no cornering or auto x
Old May 31, 2008 | 11:52 PM
NlCK B's Avatar
o ic yeah forget about the kaaz then it's not worth the maintenance 50$ oil changes suck quaife for the win just to let you know i had a knock off quaife don't know what company but it ended up cracking a spider gear just a warning watch out for knock offs i only suggest buying directly from the company or threw a trusted distributor
Wheelman-CZ
Nov 13, 2007 10:52 AM
shevlin
13
Oct 3, 2007 11:30 AM
MR FRICK
Mar 18, 2006 08:34 AM
Wazup
Jul 14, 2004 05:11 PM
