40/40 prop valves, Brake master Cylinders, ECUs, Distributors, Valvesprings and retainers, Ignitions
Old May 30, 2008 | 01:38 PM
Extradition's Avatar
Default 40/40 prop valves, Brake master Cylinders, ECUs, Distributors, Valvesprings and retainers, Ignitions
****JUST ADDED:
15/16th Integra/Civic (RS Integra) Brake Master cylinder: $30
40/40 (RS Integra; upgrade for rear disk) Prop Valve: $25
7/8 Si Brake Master Cylinder: $30
40/40 (99-00 Si) Prop Valve: $25
OBD1 B16a Injectors: $40
OBD1 D16a Dizzy: $40
OBD0 B16a Dizzy: $80
2000 ITR ECU: $120
OBD2a H23a M/T ECU: $40
OBD2a H22a A/T ECU: $50
2006 DC5 ecu (PND-A64) Automatic (perfect for HONDATA): $80
OBD2a P75 ecu (LS/ automatic): $50
EG/EH/EJ (92-95 Civic and 93-97 Del Sol) Glove Box Handle (Black, Beige, and Grey): $10 each
EG/EH/EJ 4 door Rear Handles (deletes keyhole and HELPS STOP THEIVES): $20
92-95 Civic Doors (RED, with side Mouldings): $50 each
92-95 Civic HATCH Rear Glass: $70
SOHC Mugen Valvecover (Brand New and RED): $100
2000 Civic Si Clutch Master Cylinder: $30
OBD1 P0B Non-Vtec (F22B2 engine, Manual tranny) ECU: $30
OBD1 P06 Non-vtec (SOHC, Manual tranny): $45
OBD1 PR4 LS (DOHC, Manual tranny) ECU: $50
OBD0 PR4 LS (DOHC, Manual tranny) ECU: $35
Pre-OBD0 PG7 LS (DOHC, Manual Tranny) ECU: $30
JDM GSR 4-2-1 header w/ heatshield: $50
OBD1 (B-series) Alternator: $50
B-series Starter: $40
OBD0 B-series Vtec Dizzy: $100
OBD1 B-series NON-Vtec Dizzy: $60
JDM B16a (SiR-II) camshafts: $40
JDM B16a Intake Manifold and fuel rail: $50
JDM B16a Valves: $50
JDM SiR-G (B18C/GSR) camshafts: $60
JDM SiR-G retainers and valvesprings (1 set of Dual Inner): $60
LS pistons and Rods (81 mms): $60
92-95 Honda Civic Heater Core: $40
92-95 Honda Civic Winshield wiper Motor: $30
92-95 Honda Civic Sedan rear corner lights (set): $40
92-95 Honda Civic Ignition w/ key: $60
92-95 Honda Civic Interior wiring harness (uncut): $100
92-95 Honda Civic Turn Signal switch: $30
92-95 Honda Civic High-beam low-beam switch: $30
92-95 Honda Civic Hatchback Back seat windows: $30 each
92-95 Honda Civic 2-Door Passenger window: $40
Apexi VAFC (Grey) with harness and mounting stand: $100.00
MSD Blaster SS coil (New): $20
Accel B-series Internal Coils (New): $40
1996 LS crankshaft: $60
1996 LS rods and pistons: $60
**I'm also parting out a 1996 Honda Civic SEDAN (4-DOOR) DX; I have glass, doors, mirrors (non-power), window regulators, brake boosters, steering rack, interior panels, and a lot of other items including a right rear 1/4 panel. If you're interested in any parts, or ANY OTHER PARTS give me a call!
(951) 247-8018 JAMES : Leave a message if I don't answer!
Old May 30, 2008 | 02:07 PM
boostnhatch's Avatar
bump
Old Jun 3, 2008 | 12:32 PM
98 eK4 siR's Avatar
Banned
Default Re: 40/40 prop valves, Brake master Cylinders, ECUs, Distributors, Valvesprings and retainers, Ignit
Old Jun 5, 2008 | 12:37 AM
Old Jun 6, 2008 | 05:54 PM
LsTurbo91's Avatar
hey you still got the rear glass for the 92 95 hatch? Does it still have the rubber molding around the glass? will you take $50 for it?
Old Jun 6, 2008 | 06:00 PM
em1loc's Avatar
pm
Old Jun 6, 2008 | 06:38 PM
Extradition
May 29, 2008 04:00 PM
Extradition
Mar 30, 2008 07:05 PM
jepistons4
Nov 17, 2004 03:44 PM
