Alternative to Rebuild?
Old Jul 16, 2002 | 07:43 AM
crxgurlllll's Avatar
Default Alternative to Rebuild?
Swapped out a smoking d16a for a zc
the d16a was burning oil
zc is doin the same thing(not as worse though)
Besides rebuilding is there any simple solution to stop it from burning oil?
Old Jul 16, 2002 | 07:49 AM
serious's Avatar
Default Re: Alternative to Rebuild? (eraser)
it kinda depends on where the oil is getting into the cylinder. switch to a higher viscocity oil will help al the way around. if oil is leaking around your valve seals, you can get additives which will help swell the seals to provide a tight fit again.
you should think about getting a leakdown test done to find out where the oil is getting into the cylinder, it might be an easier fix.
FEAR6655
11
Feb 16, 2011 10:46 AM
serjey15
Dec 4, 2010 07:20 PM
gregv
11
Dec 23, 2005 02:08 PM
Sl0wEK
Dec 5, 2004 10:12 PM
AMChev
Sep 15, 2002 10:26 AM
