Nearly Complete B18 swap! only $700!!! for EG or EF!!!
Old May 30, 2008 | 10:37 AM
Dasfinc's Avatar
Default Nearly Complete B18 swap! only $700!!! for EG or EF!!!
1994 B18A1/B1 FULL AND COMPLETE long block (A1 block, 94 *the 142hp version* stamped B1 head) with an UDP on the alternator and a 6 puck clutch with PP and flywheel all still on the motor
*In corner of shed, bad picture but it gets the point across, I will take some more later*
Full B-series Mount set: Upper and lower, including brackets, torque mounts, and trans mounts (poly insert not included)
OBD1 P75 ECU (I have an OBD0 PR4 that can be substituted)
94-01 Axles and Midshaft
*All of the above items $700 picked up, all you'd need is a trans and shift linkage and you'll be good to go*
For an additional $100, I can provide after market B-series into EF/ED (88-91 civic) engine mounts!
andytec-v
May 25, 2012 07:41 PM
D16SohcVtec
14
Jan 15, 2008 04:49 AM
JDM_Frijoles
Nov 6, 2007 07:07 PM
EGhatch87
Texas -OK -LA (Sales)
Sep 28, 2007 09:27 PM
Mr.Slippyfist
Aug 13, 2006 10:48 AM
