a6 dizzy
Old May 30, 2008 | 08:13 AM
nitewolf's Avatar
Default a6 dizzy
i got a 90-91 a6 dizzy, when i get on the throttle is sputters and sometimes it shuts the car off. i was wondering if a cap a rotor would fix the problem. thankz in advance
Old May 30, 2008 | 08:56 AM
toolbox21's Avatar
Default Re: a6 dizzy (nitewolf)
Is your car throwing and Codes???
What Car And Engine Do You Have.??
Old May 30, 2008 | 09:02 AM
nitewolf's Avatar
Default Re: a6 dizzy (toolbox21)
its throws code 9 in my friends car but no cel in mine. i kno its the dizzy because i used my friends and the problem was gone. i got a 00y8 swap obd0
Old May 30, 2008 | 09:08 AM
toolbox21's Avatar
yeah thats should do it i dont see why not, and also you can use a OBD1 D16Z6 Dizzy too and a OBD2 D16Y8 Dizzy all you will ahve to do is De-pin the dizzy plug on the OBD1 or OBD2 Dizzy and Pin You OBD0 Plug On To It
Old May 30, 2008 | 09:12 AM
nitewolf's Avatar
it wont throw any codes cause of TDC...i wont have to run an obd1 ecu? thanks
Old May 30, 2008 | 09:32 AM
toolbox21's Avatar
Nope My Buddy's Has A 91 Hatch And Is Running A Y8 With A PM6 ECU Out Of A EF Hatch Or CRX Si Which Is OBD0, And We He Has The Stock Distributor For That Motor Which Is OBD2 Dizzy And He Just Chaged The Dizzy Plug To The OBD0 Of His A6 Dizzy Some Wires May Not Be Used Im Not Sure So Youll Have To Get A Dizzy Plug Pinout
If You Dont Have All That Time To Do That Than I Would Just Buy A New Cap&Rotor
Old Jun 1, 2008 | 01:15 PM
nitewolf's Avatar
i tryed reping the obd2 dizzy to my obd0 didnt work...i was wondering if u had diagrahm or schematic...my obd0 has 9 and my obd2y8 dizzy has only 8 wires.
Old Jun 3, 2008 | 02:48 PM
nitewolf's Avatar
bump any1
Old Jun 7, 2008 | 07:54 PM
nitewolf's Avatar
i found theses two but on my y8 dizzy only have of the colors match
Old Jun 8, 2008 | 08:49 AM
thevtecnician's Avatar
Obd0-0bd2 conversion at dizzy
Obd0---------------obd2
Thick white-------yellow/green
Thin white--------thin white
Orange------------darkblue
White/blue--------red
Blue/yellow-------black
Blue/green---------yellow
Orange/blue-------green
Old Jun 9, 2008 | 03:46 PM
nitewolf's Avatar
Default Re: a6 dizzy (thevtecnician)
thanks ill elt you kno if it worked
Old Jun 23, 2008 | 10:57 PM
nitewolf's Avatar
my y8 dizzy colors are
blacc/yellow
blue
yellow/green
white/blue
orange/blue
orange
white
Modified by nitewolf at 12:11 AM 6/24/2008
Old Jun 24, 2008 | 09:47 PM
nitewolf's Avatar
bump
Old Jun 24, 2008 | 10:17 PM
crx_si-r's Avatar
hey, that hand drawn image of the distributor plugs is mine i would like if you aknowlege where you got it. i posted it before for another member.
Old Jun 24, 2008 | 10:49 PM
welfarepc's Avatar
dont pay attention to the colours pay attention to the destinations
Jmar9289
14
Jan 13, 2011 10:25 AM
Mr_Moos
15
Oct 19, 2009 10:36 PM
legron_m
Feb 7, 2007 08:05 AM
crxmex
Jan 28, 2007 01:42 AM
EF9ZC
12
Mar 8, 2006 04:59 PM
