Need advice about Spool , 1st long gear??
greetings,
my motor was 2.2 L (86x95) B20vtec.
pro3 camshaft
328flywheel hp
and the car was eg 820kg.
stock type r LSD
3,4,5 ATS close gear
4.4 FD
tyre was MT 24.5
this car spinning everywhere on 1st and 2nd gear.
i plan to go spool LSD, what brand you would suggest me..?? (the cheap and good quality)
and i need longer 1st gear also.. arround 2.9:1 or 2.85:1
but i've search everywhere there's no factory that provide it... ATS only got 3.0ish :1 ... the old version 2.9:1 was out of stock. and Toda have 2.9:1 but the sell it with the second gear, and i dont need to change my 2nd gear...
could you guys suggest me where could i go customize my 1st gear (complete with shaft)... im in indonesia so clueless...
pro3 camshaft
328flywheel hp
stock type r LSD
4.4 FD
tyre was MT 24.5
Unless you go with the Toda option then, you're looking at a custom gear. Might as well go with Toda since anything lower than 3.070 will require a new mainshaft versus just the countershaft gear.
mexii1
Transmission & Drivetrain
Mar 16, 2016 06:08 AM
