master cylinder
Old May 29, 2008 | 09:06 PM
rexfan's Avatar
Default master cylinder
I have a 91 crx HF and i changed the WHOLE breaking assembly today with the upper and lower control arms. After I was done, I went to go try the new breaks, and they would break the same. I have the rear disk breaks also but it is slow on breaking compared to my cousins EG. Do I have to change the master cylinder to give it more pressure or what? any help would be appreciated. thanx
Old May 30, 2008 | 09:43 PM
pandarex's Avatar
Default Re: master cylinder (rexfan)
you need the proportioning valve, master cylinder, and brake booster.
Old May 31, 2008 | 03:28 AM
turboZChatch's Avatar
Default Re: master cylinder (pandarex)
When I did my rear disc I used a proportioning (can't spell) and master cylinder off a si rex and the system works perfect although I regret doing the conversion due to weight
Old May 31, 2008 | 01:10 PM
alscrx's Avatar
Default Re: master cylinder (turboZChatch)
i have a 91 Hf also and the stock booster and MC are way too small with an upgraded brake system.
You can use the 15/16's da booster and mc. Lines match up perfectly!
I personally ran a 1" GSR booster and mc . Because its ABS you would need the bigger 12mm fitting.
Also change the prop valve to a 40/40 if you have a rear disc swap!
HastyPrawn
Jun 5, 2017 07:21 AM
llantaguy
Jul 13, 2007 12:29 AM
DENCIO
Jan 1, 2004 02:42 PM
blackccoupe
Sep 14, 2003 07:23 PM
adrian1281
Aug 23, 2003 09:43 PM
