Help!! Need part number on ITR B18c rod. Same as B18c5 rod?
I have a track car with a B18c modded motor. Spun a rod bearing. Putting it back together. The machind shop said one rod got too hot to trust. DON'T want to put the wrong part in especially a rod.
Is the B18c ITR rod the same part number as a B18c5 rod? If not does anyone know the part number and if so do I need different bearings from the B18c5 or rod bolt, etc?
Thanks.
Thanks.
from acuraoemparts.com: http://www.acuraoemparts.com/d...ch=no
007 13204-P73-J01 BOLT, CONNECTING ROD 8 2000 INTEGRA 5.08 4.06 Qty:
008 13205-ME2-000 NUT, CONNECTING ROD 8 2000 INTEGRA 3.02 2.42 Qty:
009 13210-P73-000 ROD, CONNECTING 4 2000 INTEGRA 147.96 118.37 Qty:
c5 rods are sort of specific to the crank, but i think you'll be fine. just get the correct OEM bearings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apexinghonda »</TD></TR><TR><TD CLASS="quote">
Is the B18c ITR rod the same part number as a B18c5 rod? </TD></TR></TABLE>
All the Type R rods are the same, whether they are USDM, JDM, or etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apexinghonda »</TD></TR><TR><TD CLASS="quote">I have a track car with a B18c modded motor. Spun a rod bearing. Putting it back together. .....</TD></TR></TABLE>I'm just curious. Are you having the rods put togethere with loose spec or tight spec?
redline870
Apr 18, 2009 06:57 PM
