Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain
Old May 29, 2008 | 06:38 PM
WheaMyRyceGo's Avatar
Default Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain
I tried searching but I didn't find what I was looking for.
Im going to be rebuilding my head and I wanted to know if ANYONE has ran into problems with their skunk2 stage2 camshafts with the supertech valvetrain. Should I just go with the skunk2 tuner hi comp valvetrain? Ive heard many people have problems with skunk2 valvetrain so that is what steered me away.
TY in advance
Old May 29, 2008 | 06:47 PM
Sparkles's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (WheaMyRyceGo)
Well I'm using the supertech springs with skunk2 stg2 cams and a year and a half later no problems.
Old May 29, 2008 | 06:57 PM
Innes's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (Sparkles)
no, you won't have any issues, i have many customers running the supertech valvetrain with the skunk2 camshafts
Old May 29, 2008 | 07:15 PM
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (Innes)
alright thanx! i have another question. would this be setup be ok for me daily driving the car? i heard the aluminium isnt meant for DDing
Old May 30, 2008 | 08:07 AM
Its that kidfolk's Avatar
supertech valvetrain did my 6xxx miles already on my DD car I got no complains whatsoever about them.
Old May 30, 2008 | 05:31 PM
UncleD's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (Its that kidfolk)
S2 PRO Series/Super Tech/ and RM is probably the only VT that I would feel comfortable using TI retainers in a DD. RM has cylinder heads with 60k plus on the retainers with NO signs of wear, and the 3 mentioned above are more than adequate for the S2S2 profile.
Old May 31, 2008 | 11:57 AM
Brick Top's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (clean rice)
3 years of dd here with supertech's and s2s2 cams. not one problem.
Old May 31, 2008 | 05:37 PM
frostyrb's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (Brick Top)
I am in the process of putting a motor together for my brother using supertech valvetrain with Al retainers, & s2p2 cams. It will be a dd engine & combustion contraption did the head work. He does some top notch work if you are looking to get your head done also. I think you will be just fine with yor setup.
Old Jun 1, 2008 | 01:50 PM
Dark@Powers's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (frostyrb)
Everything looks fine.
When a company says "must" use with their, many times it's just so you won't go with another company..
Old Jun 1, 2008 | 05:17 PM
DarKStaR5's Avatar
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (Dark@Powers)
Not to thread jack but would this be the same case for Pro1s and supertech valvetrain?
Old Jun 1, 2008 | 07:33 PM
Default Re: Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain (DarKStaR5)
that depends, skunk2 has two different valve spring levels, the "tuner" and "pro" series. Pro being for the bigger more demanding cams. Tuner series springs can be used on pro1 cams, but skunk2 reccomends pro series. It all depends on where the supertech springs are, if they would below skunk2 pro series in [hardness?? spring rate???] - (I forgot how valve springs are measured...) then I would not....
Old Jun 2, 2008 | 05:01 AM
mar778c's Avatar
Community Builder
Community Influencer
With supertech or tuner series, you should have no problems if installed correctly.
keepinitrehaal
Feb 18, 2010 07:48 PM
=ITRpoweredEK9=
Sep 15, 2005 04:50 AM
cal25
Jan 20, 2005 04:46 PM
VsR785
Jul 12, 2004 08:53 PM
JDM_Risa
Apr 9, 2003 07:48 PM
