b16 built head, t3/04e 60 trim, neptune build
official honda whore
well here is my build, finally got it dynoed and it will make me happy for now, if i get bored i can always get a retune and turn it up some more
b16 block:
eagle rods
cp pistons
b16 head:
aebs intake manifold
gsr t/b
rocket motorsports valvetrain
gsr cams
street port/valvejob
gsr transmission:
stock axles
competition clutch stage 4 sprung
ebay cast manifold
t3/04e 60 trim stage 5 exhaust
3"dp
3" exhaust
jrc intercooler
neptune rtp tuned by john kerr of j-k-tuning.com at innovative motorworks in carlisle pa on a dynapak dyno
ended up at the end of the day with time running out so we kept it at 15lbs (16lbs then falls back down to 15 till redline)
will have dyno sheet up tomorrow when i get it sent from john, i tried to take a pic of the dyno sheet but it just didnt work out too well
at 15lbs it made 340+ blowing off the intercooler piping at the end of the run
btw, having troubles setting up pwm boost control, i have the port to the left of the filter going to the top of the w/g and the port to the right going to i/m and it cycles but just doesnt do anything, do i need to have the source for the bottom port of the wastegate to be the same source for the feed on the solenoid? everything via neptune is working properly but we couldnt get it to turn up the boost with the solenoid
pictures of the car:
Modified by EARLdaSQUIRREL at 11:49 PM 5/30/2008
Modified by EARLdaSQUIRREL at 8:35 PM 6/17/2008
b16 block:
eagle rods
cp pistons
b16 head:
gsr t/b
gsr cams
gsr transmission:
stock axles
ebay cast manifold
3"dp
3" exhaust
jrc intercooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 »</TD></TR><TR><TD CLASS="quote">Not bad man......glad to see you get it together. Hit me up when you're ready for a manifold</TD></TR></TABLE>
That is exactly what this setup needs!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
ya but you know me, if i get a top mount or equal length i will have to upgrade to a bigger block, then bigger turbo and before ya know it i will have a race car that i TRY to daily drive ha ha
</TD></TR></TABLE>ya but you know me, if i get a top mount or equal length i will have to upgrade to a bigger block, then bigger turbo and before ya know it i will have a race car that i TRY to daily drive ha ha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">I made 650whp@23 psi with log manifold.
nice car btw</TD></TR></TABLE>
thanks
got the boost solenoid and boost by gear/rpm working today
i just t'd into the source for the solenoid and used that as my source for the w/g and it decided it wanted to work today, wish it would have worked on the dyno but oh well if im down in the area again im sure it wont take much to get it all nice and pretty on the graph, now im just waiting on the graph from d-rob
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">Oh, you mean this old thing?
Glad to hear you got the PWM working well.
- Derek</TD></TR></TABLE>
thanks derek
with the solenoid it felt a bit sluggish to get into boost, but i will be fixing that with duty cycle the more i play with it, this whole boost by gear/rpm thing is really fun
thanks derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMLS4dr200whp »</TD></TR><TR><TD CLASS="quote">congrats buddy keep up the good work
thanks
as soon as i get some more money it will be thrown on the dyno to mess around with the boost controller and turn it up some more along with messing with the timing hopefully
</TD></TR></TABLE>thanks
ran it at the track tonight and ran
60' 2.057
330 5.535
1/8 8.305
mph 90.89
1000 10.633
1/4 12.587
mph 113.55
on 225/50 15 bfgs mounted on 00 gsr swirlies
definetly some more in it i think, i was low on gas and that was my only clean run without chargepipe issues
60' 2.057
330 5.535
1/8 8.305
mph 90.89
1000 10.633
1/4 12.587
mph 113.55
ya i was launching on anti-lag, but i think i will need to launch a little higher as it had a slight bog to it right before the 60ft mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">You traps seem low for 340whp, goodluck though. Seems like a nice setup
ya it was crazy humid and i wasnt getting 16lbs either, also i was running 10psi in first and 12 in 2nd and 140-15 in 3rd 4th
</TD></TR></TABLE>ya it was crazy humid and i wasnt getting 16lbs either, also i was running 10psi in first and 12 in 2nd and 140-15 in 3rd 4th
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman »</TD></TR><TR><TD CLASS="quote">are you running a pusher fan?</TD></TR></TABLE>
yep
yep
