2000 rpm idle
Old May 29, 2008 | 06:30 PM
jands's Avatar
Default 2000 rpm idle
well i am bought to buy a 91 hatch with a 94 ls engine swap the engine is running on a b16 ecu cause the guy was plannin on doing ls/vtec well ne ways it idles at 2000 rpms and i got to thinking about it and could it be the ecu?? i was also think bout it being the idle air control valve being dirty cause he has been running it with no intake/air filter
Old May 29, 2008 | 09:57 PM
thorclark's Avatar
Default Re: 2000 rpm idle (jands)
how much u payin? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jands &raquo;</TD></TR><TR><TD CLASS="quote">well i am bought to buy a 91 hatch with a 94 ls engine swap the engine is running on a b16 ecu cause the guy was plannin on doing ls/vtec well ne ways it idles at 2000 rpms and i got to thinking about it and could it be the ecu?? i was also think bout it being the idle air control valve being dirty cause he has been running it with no intake/air filter</TD></TR></TABLE>
Old May 30, 2008 | 01:16 PM
jands's Avatar
Default Re: 2000 rpm idle (thorclark)
he asking 3000 and im hoping that its nothin major about the idle could it be the b16 ecu or is most likely the iacv
Old May 30, 2008 | 03:50 PM
gearhead16's Avatar
check the fast idle valve on the bottom of the throttle body pull off the one side and youll see a white plastic screw thing and screw it almost all the way back leave it like a turn or so from all the way.
Old May 31, 2008 | 01:32 PM
jands's Avatar
Default Re: 2000 rpm idle (gearhead16)
its cant be that cause when you first start it up it goes to a lil less then 3000 then falls down to 2000 so i dont think thats it
Old Jun 3, 2008 | 02:05 PM
jands's Avatar
the coolant line to the throttle body are teed into a line from the back of the throttle body could this be why it is idling so fast ? but i will check the screw and see if it helps any
Rahz
Jan 17, 2014 01:27 PM
xxi2icexx
Apr 6, 2009 09:50 PM
ThatsLsVtec
Sep 6, 2005 07:20 PM
Dancing is Forbidden
12
Mar 7, 2004 08:29 PM
civicdragger818
Feb 9, 2003 10:29 PM
