accord 98 overheating
hi, My accord 9 started to over heat when i drove to Canada last weekend. I had to drive it with heat on and i also noticed that with AC on, the temperatue gauage was down to normal. I guess the fan turns on maybe thts why car was good. Please comments is much appreciated as to what it could be.
Thanks a much..
Thanks a much..
Do you know how many cylinders your car has?
Thats good to know the temp drops with A/C on, proves the fan motors are good.
Now will the fans cycle when the temp gauge is about 1/2 way, A/C off?
Is the coolant full?
Would you be able to do some simple tests with a test light or multi meter?
I'll be happy to look up more info if I can find out what engine/model you have.
its 4 cylinder 98 accord ex, and yes the fan doesnt turn on with the temp guage half up.
then i guess it should be the fan motor?
let me know what test u are talking about and will look into it..
temp sensor=NO
fan relay=NO
fan motor=NO
coolant level =Always a good idea.
Post ****** jumping in with useless crap just to up their post count. Sheesh
YES You need to be sure the coolant level is full,
The Temp SENSOR has no effect as it is sending info to the ECU as to the head coolant temp.
Fan Relay the fans are running with the A/C on.
Fan motors fans are running with the A/C on.
Diagnostics;
There is a temp SWITCH Green wire/ Black wire at the T-stat cover housing that should turn on [continuity] when the temp of the coolant is 196-203 degrees F , more than 1/2 way of the temp guage.
You could also pull the plug from that Temp switch and jumper the connectors to make the fans turn on, key on engine running.
These simple checks will help to decide the problem or if further testing is needed.
fan relay=NO
fan motor=NO
Diagnostics;
plumcrazebody
Sep 25, 2010 03:14 AM
walrus_07
Feb 21, 2009 10:16 PM
