DTC obd 2 connector? Where is located on the 96 teg?
Old May 29, 2008 | 03:32 PM
VAAJ's Avatar
Default DTC obd 2 connector? Where is it located on the 96 teg?
Did Honda even make available an obd2 port for the 96 integra? I can't find the port to plug in my scanner.
Modified by VAAJ at 12:39 AM 5/30/2008
Old May 29, 2008 | 06:19 PM
VAAJ's Avatar
Default Re: DTC obd 2 connector? Where is it located on the 96 teg? (VAAJ)
can someone with a 96 teg check to see if you have the OBD 2 port?
Old May 29, 2008 | 07:44 PM
JRSC01GS-R's Avatar
im pretty sure 96 should have it, try lookin on the pass side center console area behind radio
Old May 30, 2008 | 09:28 AM
VAAJ's Avatar
Default Re: DTC obd 2 connector? Where is it located on the 96 teg? (JRSC01GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC01GS-R &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure 96 should have it, try lookin on the pass side center console area behind radio </TD></TR></TABLE>
This MAN speaks the truth. Can't believe I didn't bother looking at the passenger side.
Old May 30, 2008 | 05:45 PM
JRSC01GS-R's Avatar
glad i was able to help
2.0L EK
Wheels
Dec 16, 2009 09:28 AM
