hmmmm battery might be the problem?
well my car wont turn over and i did an amp reading on my battery, its read 0 and the cranking amp reading on the battery says 425 @ cold start and 550 on 32 F
but im getting power to all my stuff like radio and lights
could this be why my car isnt starting? that its not cranking any amps to my starter but merely putting power to it but not enough to start it?
i have no clue, i havent changed the battery cause i wanna make sure thats it.
If anything electronic in your car turns on, you battery is not at 0. How did you test the "amps".
I could be your battery or starter going out, possibly main relay, or another odd problem.
Bang on the starter a few times, then try to start it, if it turns over your starters going out.
Also take your battery to your local autoparts store to see if they can test, charge and see if it's bad.
Aug 13, 2010 09:14 PM
egvtec
12
Jun 14, 2010 10:17 PM
incognito E46
May 30, 2005 05:06 PM
