is my timing off? Pics inside (quick question)
Old May 29, 2008 | 01:59 PM
obuhmyuh's Avatar
Default is my timing off? Pics inside (quick question)
i did some searching and couldn't really find what i was looking for...
sorry for all the pictures, i just wanted to make sure, because my hayne's manual is a little broad on this subject.
Old May 29, 2008 | 02:49 PM
wmac's Avatar
look at pic 4, the |/\| should be lined up with the V below it, like a rifle sight, and they should be 'aimed' at the white mark. it looks like you are a little off.
pic 1 looks like your cam is close but not dead on, could be camera angle though.
pic 2 is close to how you want to see, but the V should be inside like this |/v\| with the white mark on the crank pulley at the V.
Modified by wmac at 3:55 PM 5/29/2008
Old May 29, 2008 | 02:55 PM
cherroneballs's Avatar
yeah look at the white mark on the crank pulley not the red one.
Old May 29, 2008 | 03:15 PM
Luserkid's Avatar
Default Re: (cherroneballs)
Looks like your timing is on even though you dont have it in TDC. Rotate a hair counter clock wise and youll be set.
Old May 29, 2008 | 10:58 PM
obuhmyuh's Avatar
Default Re: (Luserkid)
thanks, it was kind of a retarded post, but im changing out my camshaft tomorrow and i wanna make sure my timing is fine before i start messing with my cam/cam gear, im having a really hard time finding those damn marks on the crank pulley, they're kinda hard to see...
Old May 30, 2008 | 07:10 AM
wmac's Avatar
brush them off with a wire brush, you're going to want to see them when you set you ignition timing.
the91son
Apr 4, 2011 01:51 AM
jdmstyler
Jul 25, 2007 12:26 AM
jerBEAR
Feb 12, 2006 08:12 PM
