Rattle in the block after the swap PLEASE POINT ME IN THE RIGHT DIRECTION
Old May 29, 2008 | 01:37 PM
CorrodeONE's Avatar
Default Rattle in the block after the swap PLEASE POINT ME IN THE RIGHT DIRECTION
I swapped a B18A1 from a 93 teg into my ef 89 si.
-that went smooth.
after running it I had no compression like driving a beat up d15 and there was a loud rattle (like a bolt getting tossed around) coming from either the block or tranny.
I took the oil pan, splash guard blah blah blah off and all of the piston rods look fine, turned the crank a couple time and saw nothin out of the ordinary. now I am stumped.
bearings? connecting rods? I have no idea which is why i am askin... What do i look @ next?
Thank you -C1...
Old May 29, 2008 | 01:43 PM
89hatcher's Avatar
look if there are any metal shavings in the oil pan. you probably have a spun bearing or something.
Old May 29, 2008 | 01:57 PM
CorrodeONE's Avatar
Default Re: (89hatcher)
there are shavings in the pan.
Old May 29, 2008 | 01:58 PM
CorrodeONE's Avatar
little more detail on this/these bearings if you got the time. i.e. how to check em, how to take em off ect..
thank you.
pictures would be awesome too...
Old May 29, 2008 | 04:10 PM
CorrodeONE's Avatar
Default Re: (CorrodeONE)
another thing... there is rad flewid drippin from one of the oil pan bolts one of my friends told me that the knocking could be a bad water pump and also where the metal shavings are coming from... since all of the rods look good the piston walls look good the inside of the block looks good I'm thinkin either tranny, water pump or like guy above posted the rod bearings.. even though I cant see any damage or metal sticking out by the journals could it still be the bearings? the sound is similar to sticking two ten mil nuts in a tin box and shakin it up slow..
Don't like or trust shops n I know for sure I can tighten a nut just as good as the next guy just need to find what nut to hit ya feel meh..
thanks for the help guys..
Modified by CorrodeONE at 6:03 PM 5/29/2008
Old May 29, 2008 | 04:55 PM
89hatcher's Avatar
yups its if metal shavings you probably have spun a bearing. i would personally just get e new block. cause if you spun a bearing most likely you crank shaft is scarred.
Old May 29, 2008 | 05:05 PM
CorrodeONE's Avatar
little more diggin and yez'zur bearings it is. **** was in pieces lol I got a diff crank out of a 2.0 that I will use and prolly get a stoker kit or somethin... owell will be up and runnin soon.. I hope.. haha.
Old May 29, 2008 | 05:42 PM
89hatcher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CorrodeONE &raquo;</TD></TR><TR><TD CLASS="quote">little more diggin and yez'zur bearings it is. **** was in pieces lol I got a diff crank out of a 2.0 that I will use and prolly get a stoker kit or somethin... owell will be up and runnin soon.. I hope.. haha. </TD></TR></TABLE>
LS and 2.0 cranks are the same. make sure the caps aren't scratched too.
es01civy
Dec 30, 2010 06:47 PM
AlAddiN|502
May 13, 2010 01:41 AM
integra1020
Apr 14, 2006 12:33 PM
civickiller
Aug 7, 2004 03:00 PM
GruvyTune
Aug 31, 2003 03:56 PM
