what compressor
Old May 29, 2008 | 01:12 PM
sasinorm01's Avatar
Default what compressor
when swaping in a z6 in a 89 ef what compressor and condensor can be used cause its HOT!!!! IN MIAMI FLORIDA!! ****! HELP!!
Old May 29, 2008 | 02:30 PM
sasinorm01's Avatar
anyone?
Old May 29, 2008 | 02:39 PM
STREETWERKZ's Avatar
Default Re: what compressor (sasinorm01)
if you're asking a technical question, the full question should be asked in the title. or close to it.
you dont need multiple threads when you're talking about the same car/engine setup. ask 2 questions in one thread.
asking, "anyone?" isnt going to help either. if somebody knows and cares to answer you. they will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sasinorm01 &raquo;</TD></TR><TR><TD CLASS="quote">when swaping in a z6 in a 89 ef what compressor and condensor can be used </TD></TR></TABLE>
you more than likely have an ED not an EF. so, you would use the condenser from the ED chassis and the compressor that bolts to the motor. it's possible you may need the compressor from the d16z6 but your factory condenser from the ED might bolt up too.
when my lunch is over, i'll get you the OEM part numbers and schematics. that would probably be a good start.
Old May 29, 2008 | 02:45 PM
sasinorm01's Avatar
ok tanks
JMZ400
158
Jan 28, 2026 04:48 PM
Civic361
Jul 21, 2011 05:54 PM
triangle1020
Jul 16, 2009 05:26 PM
kpowerd 4g4d
Sep 4, 2006 03:32 PM
