Blox type C valve lash settings
I bought some used Blox type C camshafts for B series, but the spec sheet wasn't with it. Does someone know the valve lash settings for those cams?
Tried to contact Blox, but haven't got a reply yet.
Thanks
Modified by ej_b16a at 1:56 PM 5/29/2008
Thanks
I think you're safe with 7 and 8. Thats what my roomates S2S2's are and your camshafts have the same vtec lobe with very similar primaries.
ok thanks. I have just received an email from Blox and this is what they say:
Camshaft Specifications: DO NOT INCREASE LOBE SEPERATION
Intake:
Duration: 268° @ 0.04” Lift: 0.481”
Exhaust:
Duration: 264° @ 0.04” Lift: 0.458”
Valve settings: Set on cold motor
Intake: 0.006”
Exhaust: 0.007”
Cam Gear Settings:
Intake: +1° to +2 °
Exhaust: 0°
Fuel Pressure Settings: Factory fuel pressure is @ 48psi to 52psi
+3psi to +5psi
Ignition Timing Settings:
Set to 16° to 17° (advanced)
These settings don't look right to me. If I look to Jun3 specs they are 0.17mm and 0.19mm and for s2s2 they are 0.007" & 0.008".
@.I.Need.Money.: Did you use the Blox C's with that settings?
Intake:
Exhaust:
Intake: 0.006”
Exhaust: 0.007”
Cam Gear Settings:
Intake: +1° to +2 °
Exhaust: 0°
+3psi to +5psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej_b16a »</TD></TR><TR><TD CLASS="quote">These settings don't look right to me. If I look to Jun3 specs they are 0.17mm and 0.19mm and for s2s2 they are 0.007" & 0.008".
If you convert .17mm and .019mm to inches, you get about .007" and .008" (thousandths of an inch).
I meant the settings Blox was saying for their cams
Intake: 0.006”
Exhaust: 0.007”
But I will try 0.007" and 0.008"
thanks
Intake: 0.006”
Exhaust: 0.007”
thanks
wagon-r
Jun 11, 2013 09:32 AM
Ruben19
Aug 13, 2007 05:09 PM
JSpin
Oct 19, 2006 02:31 PM
