typer
Old Jul 16, 2002 | 04:58 AM
mini-cRx's Avatar
Default typer
does anyone know exactly how to do a typer conversion on a crx si please exactly what ill need thanks
Old Jul 16, 2002 | 06:30 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: typer (mini-cRx)
B18C5 engine
B series engine mounts for CRX.
Axles from a USDM 90-93 integra
Shift linkage from any 90+ integra, modified to fit.
Transmission, either a JDM B16 cable tranny or a USDM Type R hydro tranny.
If you use a JDM B16 tranny (J1, S1, Y1) you need do nothing extra to drop it in.
If you use a hydro tranny, you will need a custom tranny mount and hydro clutch convertion.
A reprogrammed PR3 or PWO ECU.
Your wiring harness, plus VTEC related wiring plugs.
If you use a PR3 or PWO ECU use your Si injectors.
Money, lots of money for all the little crap you are going to run into.
I have done Three B18C5 swaps on CRXs, and a crap load of B16 swaps.
None has gone 100% smoothly, there is always some little thing that needs to be either replaced or modified.
Old Jul 16, 2002 | 06:13 PM
mini-cRx's Avatar
Default Re: typer (Spaceballs the lunch box)
what do i do to be able to use the typer caliprs on my suspension need help
dc4ok
May 25, 2011 07:36 PM
crxsi361
Dec 22, 2009 11:19 AM
RollingSuicide
Transmission & Drivetrain
Jul 22, 2009 05:29 PM
v13tx1301
10
Nov 7, 2007 10:43 PM
CRX A4
Apr 8, 2003 07:10 AM
