** EG, EK and DC - cheap parts, wheels + tires, random junk... **
Set of (4) ICW wheels. – model unknown
Asking $250 OBO
Size: 16” x 7”
Offset: 38
Bolt circle: 4 x 100 and 4 x 114.3
Center bore: 73.10
Weight: 36 pounds w/ tires
Finish: painted silver spokes, polished rim and center
Condition: painted area is very good, but clear is peeling off some of the polished areas. Some wheels are better than others, see pics. Light curbage here and there.
INCLUDES LUGS AND KEY
<u>Wheel 1: </u>
Tire: 205/50-16 FateO AR-550, (2) bubbles in sidewall, ~ 4/32” tread left
<u>Wheel 2: </u>
Tire: 205/50-16 Firestone Firehawk GTA, ~ 8/32” tread left
<u>Wheel 3: </u>
Tire: 205/50-16 FateO AR-550, bad camber wear on inside shoulder, ~ 8/32” tread left
<u>Wheel 4: </u>
Tire: 205/50-16 FateO AR-550, ~ 10/32” tread left
testing waters – set of (4) GSR “fat fives”
Finish: professionally painted gunmetal, too many chips and curb marks to count
Tires: 195/50-15 BFG G-Force. ~ 6-8/32” all around, camber worn and out of balance
92-95 Civic 9.5” non-ABS front knuckle assembly – will separate
Make offers on parts you need/desire or as a package.
Knuckles: bearings are shot, lower ball joints were newly installed though
Rotors: Brembo blanks, low mileage
Pads: Axxis Ultimates, low mileage
Calipers: approx 180,000 miles, were working fine when they came off, missing (1) banjo bolt
OEM rebuild kit for 9.5” front calipers
Asking $15
One unopened, one opened to see if I could use any of the parts on 10.2” calipers, but could not. Complete:
NEW Axxis Ultimates for 9.5” front calipers
Asking $30
96-00 Civic rear drum assembly – will separate
Make offers on parts you need/desire or complete package. Everything came off a 2000 EX w/ 69,000 miles. Includes unopened drums, e-brake cables, rubber brake lines and prop valve.
94-01 Integra GSR 1” brake master cylinder and booster
Asking $100 complete
94-01 Integra rear trailing arms + compensator arms
Make offer
Civic rear trailing arm brake line brackets – drum only
Make offer
B18b1 OBD2 engine wiring harness
Distributor and CFK plugs have been cut off. Take what’s left or make me an offer for specific plugs.
CFK sensor – knock sensor – 8 pin dizzy connector (broken)
Make offer
B18a1/b1/B20 oil pan – tapped w/ return
Asking $20.
Multiple dents
DOHC VTEC valve cover gasket set – incomplete
Asking $20
Gasket and plug tube gaskets are there, but I took the washers for my LS.
OEM 22mm swap back brackets for CTR/ITR rear sway - used
Asking $5 + shipping
92-95 Civic rear tailgate catches
99-00 Civic hazard switch
D16y8 engine wire harness cover and intake manifold bracket
Make offers
DC2 rear bracket
Asking $25 + shipping
B18b1 drivers side engine mount
Asking $15 + shipping
Integra P73 AC compressor bracket - no stud or adjuster
Asking $10 + shipping
DC2 AC compressor
Make offer
Alpine remote control I found in my car when I bought it - given to wordsofvenom
DC2 front tranny mount - sold to dafuzzbudd
B18b1 upper drivers side mount - sold to EG6_Axle
More to come, so please check back.
Trades considered. Let me know if you’ve got EK or LS parts.
Modified by 94CivicSi at 7:22 PM 6/4/2008
Asking $250 OBO
Size: 16” x 7”
Offset: 38
Center bore: 73.10
<u>Wheel 1: </u>
<u>Wheel 2: </u>
<u>Wheel 3: </u>
<u>Wheel 4: </u>
Asking $15
Asking $30
Make offer
Make offer
Make offer
Asking $20.
Multiple dents
Asking $20
Make offers
DC2 rear bracket
DC2 AC compressor
Make offer
LookingforEvos
Dec 4, 2015 07:30 PM
kptrulee
Apr 3, 2006 10:17 AM
