Koni yellow perch
Old May 29, 2008 | 08:36 AM
97BB6Type-SH's Avatar
Default Koni yellow perch
Searched. Currently on mt 5th gen im lowered on Ground control and koni yellows. i have the GC almost to the lowest possible, withbarely thread left and i still have a finger or less gap in the front. its been about 6 month since ive had them on. Now i would like to drop it just a little bit more in the front but i have no more thread on the GC. I read that i could take everything out again and set the perch on the Koni's to the lowest perch. im assuming if i do that then it will free up my GC and let me adjust them lower. Is the any negative feedback about putting the koni's on the lowest perch so that my GC wont be on the last thread and i can free them up a little. any advice is thanked.
Old May 29, 2008 | 08:46 AM
street_ride14's Avatar
Default Re: Koni yellow perch (97BB6Type-SH)
Gotta love Koni for there perch system. No negatives at all, just be careful about bottoming out your shocks with the lowest perch setting. I have the same exact setup in my basement, soon will be on my 4th gen. Good luck.
Old May 29, 2008 | 11:43 AM
my9thtry's Avatar
Default Re: Koni yellow perch (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">Gotta love Koni for there perch system. No negatives at all, just be careful about bottoming out your shocks with the lowest perch setting. I have the same exact setup in my basement, soon will be on my 4th gen. Good luck.</TD></TR></TABLE>
Unless they started making new Koni's in the past two years the front only have two settings not three.
Its about a 1 inch difference (20mm) and personally i don't like how it rides on the lowest setting good luck.
Old May 29, 2008 | 02:16 PM
Default Re: Koni yellow perch (my9thtry)
The ride quality is what i was afraid of. but i also hate having the GC almost on the last thread. thats why i was thinking maybe lowering the perch only on the front so the GC can have some spare threads and still be low. Is anyone currently running this low perch on the front and the middle perch on the rear? if so , please let me know how it rides?
Old May 29, 2008 | 03:18 PM
snobordboy's Avatar
Moderator
What you are thinking of doing is just fine, since if you adjust the perch down lower, you can have more control of your ground control threaded area, without reaching the end of your threads. I have my Konis set up with the perch on the lowest in front, and one up in the back, and it works fine, although honestly too low for driving most places. I am also running neuspeed race springs as opposed to a coilover though.
And the Koni should have 3 perch slots for the normal shocks, and Neuspeed sells them with 5 adjustment slots for height, I know this is true since its whats on my car!
Old May 30, 2008 | 11:01 AM
my9thtry's Avatar
Default Re: (snobordboi)
Koni Yellow's do not come with 3 perchs in the front unless i have the only set with two perchs.
Old May 30, 2008 | 11:32 PM
snobordboy's Avatar
Moderator
hmm wierd, I thought they all had 3 unless they were the Neuspeed ones, but maybe I am wrong.
owneyboy
Suspension & Brakes
Feb 4, 2009 10:15 PM
DR.DRum
Mar 20, 2003 05:27 AM
sazaks
Dec 18, 2002 09:37 AM
Superhatch
20
Feb 21, 2002 12:37 PM
