Blown fuse? helpppp :(!
Old May 28, 2008 | 11:50 PM
Shannon626's Avatar
Default Blown fuse? helpppp :(!
okay so i was playin with the trunk light earlier and i was trying to swap out the stock light for another one when suddenly it stopped working ! the stock light and the new light both don't work when the trunk hatch is open. on top of that, the dome light and side door lights don't turn on either. everything else seems to work fine so i'm assuming i might've blown a fuse? if so, does anyone know where exactly i can find this broken fuse and replace it, and also what kinda fuse it is. thankie!
Old May 29, 2008 | 07:22 AM
Mr Yamada's Avatar
Default Re: Blown fuse? helpppp :(! (Shannon626)
You might receive better help if you would post the year and model of your Accord
Old May 29, 2008 | 08:13 AM
Shannon626's Avatar
oh, sorry forgot :D 99 accord ex coupe
Old May 29, 2008 | 10:12 AM
Honda_Accord's Avatar
look for the fuse box under the hood, and the one at the driver side kick panel where ur left foot goes (if u got an auto and dont need to worry about clutch)
if its blown the metal inside will be cut in half usually, so you take that, it will have a number at the top and go buy the same number fuse and replace.
Old May 29, 2008 | 11:03 PM
Shannon626's Avatar
okay so i found the fuse and i was able to replace it. i got all the interior lights working now, but for some reason my trunk light still doesn't work. anyone have any clue as to what could be the cause? :/
dansaleen_04
Jul 22, 2013 11:19 AM
1992gsrblack
May 3, 2011 12:32 PM
Patrick_S
Jun 8, 2006 07:07 AM
guywitaDA
Apr 21, 2004 09:58 PM
