smoke from the exhaust and spark from valve cover grommet
Old May 28, 2008 | 08:39 PM
dungy's Avatar
Default smoke from the exhaust and spark from valve cover grommet
hi guys,
i am getting smoke coming out of the exhaust and i'm not sure what's going on
the motor is a gsr block w an si head
The motor was just rebuilt by a reputable machine shop
it did this really heavily upon first startup and now just slightly
it has a kind of like burning plastic smell to it
For the rebuild all new gaskets were used
that's the best i can explain it
As for the spark I am getting spark from the valve cover grommet just above cylinder # 3 (Looking from the front to the back of the car)
I had checked grounds and added grounds seeing it in another post here but no help.... it is still sparking....
any help appreciated and thanks in advance
Old May 28, 2008 | 09:49 PM
turbociv910's Avatar
Default Re: smoke from the exhaust and spark from valve cover grommet (dungy)
your getting electric current thought a RUBBER grommet
Old Jun 2, 2008 | 07:23 AM
dungy's Avatar
Default Re: smoke from the exhaust and spark from valve cover grommet (turbociv910)
well this is where it's coming from so that was the best explanation i can give
has anyone encountered any of these problems?
if so how were your fixes.
I rarely post because i am usually able to just search on this forum for the information, but in this case i was not able to find any answers
Old Jun 2, 2008 | 08:15 AM
standbackimapro's Avatar
Whens the last time you changed the spark plug wires?
There probably arcing out to the valve cover nut, Change the wires
also what colors the smoke from the exhaust
Old Jun 2, 2008 | 10:29 AM
dungy's Avatar
Default Re: (standbackimapro)
the color of the smoke is whitish
and has this odor to it, kind of like burning plastic
i initially thought it was water/coolant
but my fluids did not lower at all
I do know my injectors need to be changed..... could it be unburned gas or simply running super rich?
and the spark plug wires are pretty old, we will change those and see if there are changes with the spark...
As i look closer the spark starts from under the grommet because i can see it glowing below it for a little bit before it goes out...
90hondaccord
May 25, 2014 10:42 PM
ef8pro
Jul 27, 2006 10:02 PM
lke2drvgsr
Sep 29, 2003 07:25 PM
n1_ek
Aug 26, 2003 11:12 PM
Diego Boost
Jan 6, 2003 01:28 PM
