SOHC ZC
Old May 28, 2008 | 08:39 PM
EFsauce's Avatar
Default SOHC ZC
I have searched long and hard for any information on sohc ZC cams. But nothing comes up specifically for "zc" (cuz the seach field is too short).
SO.. my question is.. my cam seals on my sohc ZC are cracked and leaking. Do d16 seals fit? or do i need to find specifically ZC cams/seals. ive heard that the cams are different.. some people say they are identical.. i don't f*ing know.
What and where should I get to replace the seals?
Old May 28, 2008 | 09:50 PM
hondacivic90zc's Avatar
Default Re: SOHC ZC (EFsauce)
the camshaft is essentially the same with the only difference being to the best of my knowledge the duration on the exhaust lobes of the cam. As far as seals go, the d16a6 seals will work just fine
Old May 28, 2008 | 09:58 PM
90sedan's Avatar
Yes, the cam seal from a d16 will work. The ends of the cam shafts are the same diameter, and i would assume this is for a non-vtec zc, so just order a cam seal for the d16a6 from honda.
Old May 28, 2008 | 10:15 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: SOHC ZC (90sedan)
it's an a6, don't get a hard on
Old May 28, 2008 | 10:28 PM
EFsauce's Avatar
sees a sohc ZC. booing*
Old May 28, 2008 | 10:29 PM
90sedan's Avatar
Default Re: (EFsauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFsauce &raquo;</TD></TR><TR><TD CLASS="quote">sees a sohc ZC. booing*</TD></TR></TABLE>
Old May 28, 2008 | 10:32 PM
EFsauce's Avatar
Default Re: (90sedan)
Let me re-edit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">it's an a6, don't get a hard on </TD></TR></TABLE>
booing = my hard on.
btw.
https://honda-tech.com/zerothread?id=758441
i quote "So for the individuals who insist it is the same as a d16a6, it is not. Where it gets the 10hp...the debate continues."
Old May 29, 2008 | 11:29 AM
SIred91's Avatar
Rainman
Two threads on the same thing huh?
All parts between those two motors interchange. Period.
Old May 29, 2008 | 02:45 PM
STREETWERKZ's Avatar
btw.
i quote "So for the individuals who insist it is the same as a d16a6, it is not. Where it gets the 10hp...the debate continues."</TD></TR></TABLE>
that thread blows worse than this one.
EFsauce
May 29, 2008 11:27 AM
JaHnAbOi
17
Jul 17, 2006 05:07 PM
racer-025
15
Jun 9, 2005 04:00 AM
icuracing.com
Feb 4, 2005 02:20 AM
davens
Feb 6, 2004 07:21 AM
