zc cams
Old May 28, 2008 | 08:39 PM
EFsauce's Avatar
Default zc cams
I have searched long and hard for any information on sohc ZC cams. But nothing comes up specifically for "zc" (cuz the seach field is too short).
SO.. my question is.. my cam seals on my sohc ZC are cracked and leaking. Do d16 seals fit? or do i need to find specifically ZC cams/seals. ive heard that the cams are different.. some people say they are identical.. i don't f*ing know.
What and where should I get to replace the seals?
Old May 28, 2008 | 09:09 PM
SOHCwarrior's Avatar
Default Re: zc cams (EFsauce)
https://honda-tech.com/zerothread?id=758441
don't know if the original poster is an active member, but you may want to pm him, it was a very good chart when it was up
Old May 29, 2008 | 10:13 AM
Floored's Avatar
Yes it will work. I have a ZC cam and purchased new cam seals from Honda. I told them I needed it for an SI (although I would think the DX/STD cam seals would work as well).
Also the part of the cam that is different is either the exhaust or intake lobes (i forget which and don't feel like searching).
Old May 29, 2008 | 11:27 AM
SIred91's Avatar
Rainman
Default Re: zc cams (Floored)
So, since your question in your other thread was answered.....and you make
another thread about the EXACT SAME THING?
What part of every part of the sohc non vtec ZC is interchangeable with
the A6 do you NOT understand?
tyler100
Aug 25, 2008 09:20 PM
EFsauce
May 29, 2008 02:45 PM
White91EF
Jun 1, 2007 12:35 AM
