Car Smoke Problem !
Old May 28, 2008 | 07:04 PM
zcmotor's Avatar
Default Car Smoke Problem !
Ok I got to my car , Turn it on and it starts to shake acting funny ,and I look outside and notice my car is blowing White smoke out from the tail pipe Ive been having this problem but never know what it is. I already changed the Head Gasket , Resistor Box, Main relay, injectors, pretty much everything what could be causing the car to star blowing white smoke ? its as if it's ok couple of months then it goes away then again comes back again. I have a ZC 1.6 on a 88 honda civic. Some Help here People.
Old May 28, 2008 | 08:06 PM
QuickStyle's Avatar
did you have the cylinder head checked for straightness when you had it off for the head gasket replacement? warped head is just as bad as a blown head gasket. you are on the right track tho... white smoke = coolant in the combustion chamber
Old May 28, 2008 | 08:07 PM
wiZCo's Avatar
Stouts 'n' Scotch
Do a compression test. Usually when you're blowing white smoke, it's a HG issue.
Old May 28, 2008 | 08:16 PM
zcmotor's Avatar
I got the head resurfaced and after the head gasket replaced did a compression test it was around 160-170. would the head just get warped after 2 or 3 months of use ???
Old May 28, 2008 | 10:10 PM
zcmotor's Avatar
anyone know what's going on here ?????
Old May 29, 2008 | 06:35 AM
wiZCo's Avatar
Stouts 'n' Scotch
You could've gotten a bad HG the last time. Do the compression test again.
Old May 29, 2008 | 06:55 AM
zcmotor's Avatar
Default Re: (wiZCo)
this time happend when i took off the ECU cover and i was looking at the wiring but did not change nothing and after that it started doing the white smoke......man this sucks
Old May 29, 2008 | 09:55 AM
toolbox21's Avatar
Default Re: Car Smoke Problem ! (zcmotor)
Well if your block has low compression it will smoke. i had a personal experience where i had really bad white smoke to where i could see nothing behind me, and a week later i spun a rod bearing. so if your rod bearing gets warped from no water or and other senario's then yuor block may be int he process of spinning a rod bearing, keep me updated and let me know whats going on
Old May 29, 2008 | 12:48 PM
zcmotor's Avatar
Well im just going to buy a new motor i dont want to put more money on it. But when i accelerate white smoke comes out..sooo yea when i get home ill take a look at it
Old May 29, 2008 | 07:04 PM
toolbox21's Avatar
Default Re: (zcmotor)
alrighty, yeah spinning a rod bearing is usually cause by being ran without or with low oil for a distance, so if you have a slow oil leak then that will do it too. but keep me posted and if you need and suggestion on picking a engine lemmi know i have delt with alot of honda engine and i can tell you alot of sh*t
PEACE
benjamin
Jul 2, 2022 11:49 AM
Clash0901
12
Jun 6, 2010 01:36 PM
honda luv
Jun 30, 2009 12:05 PM
quick87crxsi
Nov 26, 2006 05:42 PM
plastik462003
Apr 30, 2003 05:25 PM
