ecsta spt wearing out fast, suspension related?
Old May 28, 2008 | 06:50 PM
Shirozu's Avatar
Default ecsta spt wearing out fast, suspension related?
well i just failed my inspection for having bald ecsta spt tires in front after only 2 years / 17000 miles on them. whenever I go over speed bumps and such before when tread was decent and properly inflated, the car basically rattles crazily and makes loud thud. would the suspension be a cause for the tires wearing out so fast?
Old May 29, 2008 | 11:30 AM
TunerN00b's Avatar
Default Re: ecsta spt wearing out fast, suspension related? (Shirozu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shirozu &raquo;</TD></TR><TR><TD CLASS="quote">well i just failed my inspection for having bald ecsta spt tires in front after only 2 years / 17000 miles on them. whenever I go over speed bumps and such before when tread was decent and properly inflated, the car basically rattles crazily and makes loud thud. would the suspension be a cause for the tires wearing out so fast?</TD></TR></TABLE>
Tires wearing out very fast is generally an indication that your toe is off.
When was the last time the car had an alignment?
What were your alignment settings after the alignment?
Old May 29, 2008 | 04:59 PM
Shirozu's Avatar
Default Re: ecsta spt wearing out fast, suspension related? (TunerN00b)
I had an alignment right after I changed my old tires to the spt's so alignment wasn't the cause.
Old May 29, 2008 | 05:37 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shirozu &raquo;</TD></TR><TR><TD CLASS="quote">I had an alignment right after I changed my old tires to the spt's so alignment wasn't the cause.</TD></TR></TABLE>
In other words, you haven't had an alignment in 2 years. This could be the cause, especially with older suspension parts that don't always want to keep the alignment for very long.
And if you suspect that something in your suspension is wrong, jack up the car and check. On stands, if you try and move the wheel, any play will indicate bushing and/or other suspension issues. A very worn bushing won't hold your alignment, and you'll wear tires.
regal1975
Aug 28, 2013 07:36 AM
wtsapexipowerfc
Apr 27, 2011 07:26 AM
jessefg1
Honda Civic (2006 - 2015)
Mar 24, 2008 04:56 PM
jrv2u
Dec 1, 2004 10:06 PM
jonnybravo
Oct 2, 2002 08:36 AM
