Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Question about Comptech / CT-Engineering Header - Sedan
Old May 28, 2008 | 06:19 PM
djarch's Avatar
Default Question about Comptech / CT-Engineering Header - Sedan
So I bought the Comptech shorty header listed here:
http://www.ct-engineering.com/....html
and I probably didn't do enough research on it before I bought it (because I got a pretty good deal on it). I have an 07 Si Sedan - from my understanding any coupe parts fit fine, except for the exhaust, because of the 2" difference.
So theoretically, I should have no problems installing this header on my sedan, right? I don't want to attempt the installation, only to find out something doesn't fit...
I've searched for a sedan with it on, or a DIY installation guide, but have come up empty. Also, assuming this is do-able, any idea what other parts I may need to get this up and running?
Thanks for the help guys.
Old May 28, 2008 | 06:58 PM
i-VTEC_DOHC's Avatar
Default Re: Question about Comptech / CT-Engineering Header - Sedan (djarch)
well i dont think theres a problem and it should fit. since its just the shorty header. if it was a one piece race header for the coupe and your trying to fit it on the sedan, then you might run into problems. but it should fit since the header doesnt run out of the engine bay. but they say that there are negligible gains with just a shorty header =/
Old May 28, 2008 | 09:12 PM
djarch's Avatar
Yeah, I understand it's probably only a 1 hp gain (by itself) I got it for 240 shipped tho.
PLUS it's Comptech. Plus, when paired with an exhaust, it's supposed to give a significant gain. And it's Comptech.
Besides all of that... I'm going for a full Carb Exempt solution.
Old Mar 7, 2009 | 06:47 PM
JackedupSOB's Avatar
I know this post is kinda old but where did you get the header that cheap because I also dont want to remove my stock cat
Old Mar 8, 2009 | 05:16 PM
203_EM2's Avatar
i just installed my BCRH and ill tell you for the work into putting one in its not worth going with a shorty header i say go RH or dont even bother it took me 3 1/2 hrs with a lift and air tools to install mine and im not a "noob" at working on cars
Old Mar 8, 2009 | 08:05 PM
vietfella's Avatar
the comptech header doesn't make any power by it self. if coupled with a high flow cat or the RT cat you will probably see some gains.
Old Mar 8, 2009 | 09:43 PM
Zeusone's Avatar
3 1/2 with a lift? wow.
Old Mar 9, 2009 | 07:29 PM
203_EM2's Avatar
yea that **** was a pain in the *** no room to get to anything and im a small guy with small arms lol
Old Mar 9, 2009 | 09:29 PM
Zeusone's Avatar
takes me almost 3 with a jackstands and jack
Old Mar 10, 2009 | 06:57 PM
would the install have been easier if the header was a two piece set up, basically using a shorty and high flow cat ?
Acura4life5
Dec 31, 2014 01:30 PM
dinko
Jun 25, 2007 10:01 AM
95whitegizzer
Jan 23, 2007 09:26 PM
SPORT INJECTION
Sep 8, 2002 12:30 AM
