da 90-93 integra axle problems????????????axel seems to short and is binding up?????
Old May 28, 2008 | 05:54 PM
h22_da9's Avatar
Default da 90-93 integra axle problems????????????axel seems to short and is binding up?????
well heres the problem i got a 92 integra with a b20 swap and a j-1 cable tranny,i keep breaking the DRIVER SIDE axle,have no idea why?????it seems the passenger side seems the right length never had a problems with that side,but the driver side seems way to short cause when i put the axle back in with the bolt not tightened and the wheel is straight the boot still creases big time!!!then when i tighten it it creases even more so i know something is wrong i been told i need a longer axle,or something with the half shaft is wrong but everything is bolted up right,is there difference between the b20,gsr,ls halfshafts?or what else could be the problem?all help will be greatly appreciated thanks,the driver side axle is from autozone but i went to other part stores and they are the same length??
Old May 29, 2008 | 02:49 PM
h22_da9's Avatar
Default Re: da 90-93 integra axle problems????????????axel seems to short and is binding up????? (h22_da9)
anyone have this problem or know why this might be happening???
B16-CRX
Aug 5, 2009 09:16 AM
funtak
Feb 29, 2008 09:43 AM
crxtech
Mar 29, 2006 10:45 PM
h22ame
Mar 3, 2004 05:00 PM
velocitysir
Jun 9, 2002 04:55 PM
